3 speed on the tree ?'s
Old Dec 3, 2007 | 03:36 PM
1.3mazda's Avatar
1.3mazda
so what do i have to fix to stop my shifter from hanging up, and does any body know where i can get a pdf FSM for this truck?
Old Dec 3, 2007 | 04:08 PM
Holmesuser01's Avatar
Holmesuser01
Check all of the bushings for wear on all linkage between the shifter and the tranny. That may be all that it is.
If there is any play in the links, replace the bushings.
Old Dec 4, 2007 | 02:12 AM
PaulzF150's Avatar
PaulzF150
If the shifter is sloppy, there is a plastic bushing in the steering column that wears out and will need to be replaced. Eventually, it will not shift. Another thing is the clutch rod that goes from the clutch pedal through the floor. The ends on the clutch rod wear out and when the end breaks off, you're stuck in that gear. Had that happen at a busy intersection w/ my '83 F-100 three on the tree. I just mentioned the two main things that happened with my truck. Check all the stuff that Holmesuser mentioned. Good luck.
Old Dec 4, 2007 | 02:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I assume from your profile that you have a 1980 F100, and it's a 3 speed manual (you didn't say).
Binding in gear = Worn, broken or missing plastic snap on bushings in the two steering column selector levers, at the bottom of the steering column under the hood. This is where the two shift rods from the transmission attach.
2-E0SZ-7341-B .. Bushing / Still available from Ford ~ List price $3.07 each.
Fit: 1980/87 F100/350.
No bushings (plastic or otherwise) are used on the two transmission levers on the transmission.
Old Dec 7, 2007 | 09:50 PM
1.3mazda's Avatar
1.3mazda
okay cool thanks guys for all the help, does anybody know where to get a FSM perferbly pdf)on these trucks?
Old Dec 24, 2007 | 08:13 PM
1.3mazda's Avatar
1.3mazda
so no pdf FSM's out there kickin around on anybody's harddrive?
Old Dec 24, 2007 | 08:23 PM
Franklin2's Avatar
Franklin2
Try ebay or if you want the real thing, try www.helminc.com
Old Dec 24, 2007 | 08:48 PM
1.3mazda's Avatar
1.3mazda
[QUOTE=Franklin2]Try ebay or if you want the real thing, try www.helminc.com[/QUOTE]
no thanx much rather get it for free if i can
