1996 4x4 Hub locking problem...
Old Dec 3, 2007 | 10:59 AM
B964C's Avatar
B964C
I cannot get my four wheel drive to kick in for some reason on my 96 F-150. When i bought the truck last summer, the transfer shifter was all locked up do to the truck sitting idle for a long time. I took it all apart and greased and it and now it works good, at least showing on dash that its in 4x4 and i can hear and feel the high and low range difference but i still cant get the front wheels to catch. The front axle shafts are spinning when in but not engaging the wheels. Do you think i got a broken part in between there or the hub area needs cleaned and greased? I dont know a whole lot about 4x4 componets and still learning but dont want to cause any more damage if i can know the problem. Any advice would be greatly appreciated.
Old Dec 3, 2007 | 11:22 AM
skrinar70's Avatar
skrinar70
does it have automatic or manual front hubs, meaning do you have to get out and turn the **** on the end of the hub
Old Dec 3, 2007 | 11:35 AM
B964C's Avatar
B964C
There auto locking. Im reading that a lot of trucks are awitching to manual. Good idea?
Old Dec 3, 2007 | 11:43 AM
cjg1999's Avatar
cjg1999
if they are autolocking that is your problem. They are not locking and engaging the front wheels. You might try taking them apart and cleaning the up but your best bet might be to swap them out for some warn manual hub locks. They can easily be found in the junkyard, I got mine there, both sides for $2.
Old Dec 3, 2007 | 04:54 PM
skrinar70's Avatar
skrinar70
without a doubt, I would switch to manual hubs
Old Dec 3, 2007 | 05:50 PM
lostin90s's Avatar
lostin90s
Yep if they quit replace them and manuals r cheap
Old Dec 5, 2007 | 09:00 AM
B964C's Avatar
B964C
Thanks for the advice, ive decided to look for manuals first chance i get. I can see this will be on ongoing problem.
Old Jan 26, 2008 | 10:24 PM
thunderman's Avatar
thunderman
2003 Super Duty Automatic Hub Locking Problems
I have a Ford 350 Super Duty and the automatic hubs are not working. I took it to the dealer and they claim they haven't heard of this??? I have done some experimenting on my own changing the vaccuum shift on the fly selinoid and it didni't do anything. The four wheel drive works fine from the dash switch if I leave the hubs locked in manually, but I turn the four wheel on and off at intersections for better traction pulling a cargo trailer in the winter and I don't want to have to jump in and out to get four wheel. I don't like to drive on dry payment either with the hubs locked in for sake of convienence. I would like to fix the problem but don't know where to turn now. I hope someone can help me with this with advice or shed some light on how to fix it. Thanks.
Old Jan 27, 2008 | 06:18 AM
alz's Avatar
alz
Thunderman, just to clearify, this is the 87-96 forum. Our hubs work differently than yours.
You might try in the 4x4 forum or the SuperDuty forum.
Old Jan 27, 2008 | 05:24 PM
cpettymore7777's Avatar
cpettymore7777
i would put the manuals in too
crazyduck
Sep 19, 2010 11:22 PM
scottddove
22
Aug 16, 2009 10:15 AM
fast_fred
Feb 20, 2009 08:12 PM
ron01sd
15
Jan 3, 2008 12:48 AM
THE KING
1978 - 1996 Big Bronco
17
Jun 25, 2007 10:07 PM
