Sponsored by: Auxito
More Headlight Questions
Old Dec 3, 2007 | 10:31 AM
djfordman81005's Avatar
djfordman81005
I just got my Projector headlights and foglights put in, they light up great and look even better. But now I am wondering about lighting combinations. Is there a way to run high beams and fog lights? or fogs only? 1998 F150 4.6L 4x4
Old Dec 3, 2007 | 10:46 AM
RedDragon777's Avatar
RedDragon777
switch the wires arounf for your high and lows so the switch will be on lows and the lights will be high but when you switch to highs you will loose your fogs and have low beams unless you just put them on sperate switches to solve your problem. Just have a seperate switch and make sure to hook the fogs up to a switched source so when you turn off the key the fogs turn off so you will not worry about killing your battery by leaving the fogs on.
Old Dec 3, 2007 | 11:18 AM
djfordman81005
sounds a little compicated....like everything else on this truck i am learning. i'll get around to it....after my chip
duke5150
2004 - 2008 F150
Feb 10, 2011 04:24 PM
Lt CHEG
Nov 25, 2010 07:07 PM
dirtmonkey11
Oct 25, 2010 10:28 AM
johnh002002
1997 - 2003 F150
Jun 15, 2004 04:49 PM
