Randomly in last year you go to start and nothing. Pump does not cycle, truck doesn't start. Then, all of a sudden it fires and runs fine. It will go months or weeks with no problem, then bang.
Don't know the circuitry, but I assume there is a relay that computer fires to turn on pump. I don't think it's pump related as usually they are all or nothing. Anyone have information on this type of problem?
Freightrain/Project/anyone?
My truck (same model, year, etc.) seems to be experiencing the same issues...I have replaced fuel filter and relays. Have checked fuel pressure (a little low but within specs. barely) but to no avail. Am considering the inertial fuel cutoff switch...possibly intermittent. My truck seems to go if I hear (while listening carefully) the fuel pump whirr for a second or two upon turning the key switch. Sometimes I don't and the truck will crank but not fire. This morn I turned the switch back and forth (six to eight times maybe?) from off to run before I heard the pump cycle. Once it did, truck started. So my question is why is the fuel pump intermittent upon start up?
Ok, sounds like this is a common issue? At least someone else has typical issue. Truck doesn't quit after running, just won't always start.
I put new relay in it yesterday, pulled old one apart and looks brand new inside, so can't say it was the contacts. I think it's computer related, as not telling it to come on. WHY? Cosmic muffies?
I'm leaning a little more toward the ignition switch itself right now since cycling that thing seems to get the fuel pump going. Although I noticed that all the voltage goes thru the inertial cut out switch on the way to the pump itself, it doesn't seem logical that it would be intermittent. The truck isn't moving when it's off, and as you have experienced, once it's running, it stays running. May have to try to figure out which switch I need and try that. Since this problem is infrequent, it's hard to tell if a replacement part has made a difference.
Ya, no codes or CEL here either. Just no pump randomly. Never had to tow it, just keep trying and finally it will start and run fine. Only issue this last time was salesman that had it killed the battery before getting it to start. DOH! I suppose cycling the key and waiting for pump would be better then cranking it til it's dead!
Well happened to me today on a 2003. Hints of hard starting in the past. 2am this morning on my way to work, I had to crank and crank to start it. Same when I left work. 60 MPH she died on the way home in the middle of the freeway. Waited a moment and she started back up.
Got home and checked the fuel pressure. Just turning the key to start the pump I got 25 PSI. Started her up and revved the engine and the pressure dropped. Oh, the pressure dropped right after the pump cycled, it went from 25 psi to zero in no time.
