Battery question
Old Dec 2, 2007 | 10:37 PM
turret_plug's Avatar
turret_plug
Battery question
is 460 cold cranking amps big enough for a 302? The starter turens really slow and sometimes not at all..... voltage is 14v.... good. I bought a new starter thinking mine was maybe on the way out, but should I get a beefier battery and try that first? like a 750 CCA?..... FYI, 302 with automatic tranny
Old Dec 2, 2007 | 11:21 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
460 CCA should do the trick. Have you load tested the battery? Check your cable connections; battery, starter relay, starter connection and don't forget the block ground connection. I like to use sandpaper to clean the connections, gets um nice and shiney.
The starter could be toast, they will die if they are cranked way too long (they have a duty cycle and heat buildup will damage them) Good luck, start with the cables...
Old Dec 2, 2007 | 11:31 PM
ford390gashog's Avatar
ford390gashog
450cca? That is a tiny battery. Your truck should have come with a group 24 battery which is 770 cca. I use a group 65 which has 1000 cca.
Old Dec 3, 2007 | 07:46 AM
srercrcr's Avatar
srercrcr
I use the cheapest battery Walmart sells...as long as it fits. I don't really crank mine though, just hit the starter and VROOM.........
Old Dec 3, 2007 | 09:00 AM
turret_plug
I do the same with batteries, i think my starter and wiring is just kaput, oh well, I bought a new starter and wiring last night, so that should do the trick
marsh rat
Oct 19, 2014 09:29 PM
Fifty-Fourd
Apr 27, 2011 07:47 AM
alexchavel
Jan 7, 2008 09:23 AM
DC_78
May 26, 2006 03:30 AM
freddie
Jan 17, 2000 09:34 AM
