battery recommendations
Old Dec 3, 2007 | 06:30 PM
bfloyd4445's Avatar
bfloyd4445
Originally Posted by nmcqueen469
I am ready to purchase new batteries. Just looking for some input on what kind everyone uses. Good brands? Bad brands? Any certain type these trucks like or don't like?
I replaced the battery in my F150 after ten years even though it was still fine. Didn't want to be stuck somewhere and ten years is a long time for a batttery. It was the one that came from the fatory in my F150 so was a motorcraft.
Old Dec 3, 2007 | 06:36 PM
nmcqueen469's Avatar
nmcqueen469
I'm in the same boat. Mine crank over just fine but I can't keep mine from building up corrosion. I don't want them to give up the fight while I'm fighting a 30 acre parking lot full of snow!
Old Dec 4, 2007 | 08:46 AM
bfloyd4445's Avatar
bfloyd4445
I hear ya. The new gen batteries, or maybe its just Fords are really good but I can't aford the luxury of getting broke down in some remote mountain location. I mean, a hundred bucks for ten years of service, thats gott to be a bargin.
Old Dec 4, 2007 | 10:28 AM
rbaker6336's Avatar
rbaker6336
I put the felt washers under mine and haven't had a corroded battery in 25 years
Old Dec 4, 2007 | 10:40 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
I use felt washers and coat the terminals w/vasoline.
Old Dec 4, 2007 | 11:21 AM
SpringerPop's Avatar
SpringerPop
I just use common NLGI #2 grease.
I used to use silicone sealant, but all ya' need to do is keep the acid (that is bound to weep past an imperfect terminal-to-case seal) away from the cable connectors. Grease does a pretty-good job for me, and it's not as messy as you would think.
Vaselene would work equally-well. I just don't have any...
Pop
Old Dec 4, 2007 | 12:51 PM
bfloyd4445's Avatar
bfloyd4445
Pop
As long as it is a conducting grease and not a dialectric grease it will work fine.
Old Dec 4, 2007 | 12:59 PM
SpringerPop
In reality and practicality, on the lead battery terminals of our trucks, the type of grease doesn't really matter much. Just for the principal of it, I wouldn't use dialectric grease, as it's more expensive, but I'm confident you wouldn't ever notice a difference in THIS application.
Except for some very special-purpose greases, most all grease is relatively non-conductive. Conductive greases usually have copper or silver dust entrained. They're a family of special-purpose greases that are used in more exotic electrical and electronics applications, and are kinda' "pricey"! If I had LOTS of it, maybe I'd use it on my batteries. :-))
Pop
Old Dec 7, 2007 | 09:30 AM
dzzavid's Avatar
dzzavid
i found some one thats carrying the 930 CCA interstates i am going to pick these up today hopefully.
-dave
Old Dec 7, 2007 | 09:47 AM
bfloyd4445's Avatar
bfloyd4445
-dave
One, don't you need two? Interstate are good batts.
Old Dec 7, 2007 | 09:59 AM
dzzavid's Avatar
dzzavid
i meant "some one" as in a parts store that carries them
yes i am getting 2 at $110/each + core
thanks for the heads up though!
Old Dec 7, 2007 | 12:09 PM
bfloyd4445's Avatar
bfloyd4445
Smile
you'll be good to go for another five years at least! Don't need a dead bat in the winter for sure.
Old Dec 7, 2007 | 12:18 PM
  #28
MTMike's Avatar
MTMike
I have the Champions or whatever Sams club sells - work fine here in Montana even at 30 below and are about $100/pair. Synthetic oil helps on those cold morning starts too.
Old Dec 7, 2007 | 12:26 PM
  #29
bfloyd4445's Avatar
bfloyd4445
Been useing syn since 76, good stuff. Mobil 1 in gassers and mobil 1 delvac syn in my d's. Even my old 1975 Ford 2000 diesel tractor runs on delvac syn.
Old Dec 9, 2007 | 07:44 PM
  #30
stormyrider's Avatar
stormyrider
I would either go with Motorcraft or go to NAPA and get the Premium line.
