Sponsored by: Real Truck
How often do you change your diff fluid?
Old Dec 2, 2007 | 04:25 PM
twayneb's Avatar
twayneb
Had a driveshaft seal on the diff leaking so took it in to get it repaired and $1000 dollars later...... The yoke had to be replaced as it developed a groove in it and a new seal wouldn't fix it. I was told that, the truck has only 42000 miles on it, since it is 8 years old the oil breaks down and can cause problems in the metal. It was suggested it be changed every 2 years. I haul a 10k fiver for maybe 800 miles a year so the truck is not working hard. Any one else have a similar problem?
Old Dec 2, 2007 | 05:40 PM
RedDragon777's Avatar
RedDragon777
wow i have not changed the front diff oil since it was born and i do not think the previous owner did it. i wonder how it will look
Old Dec 2, 2007 | 09:23 PM
chaparro's Avatar
chaparro
I was told by the dealer, axle oil change in my F-250 superduty every 100K miles. Truth? don't know.
Old Dec 2, 2007 | 11:46 PM
UP_There's Avatar
UP_There
every two years for me........not sure if it's needed or not, but repair bills REALLY suck when it's something you could've prevented!!!!
Old Dec 3, 2007 | 04:19 AM
rusty350250's Avatar
rusty350250
i like to change mine out every two years or so. diff gears and bearings during use create tiny metal particles as the two parts turn together the particles stay in the oil so thats why i like to change all my fluids around every 2 years. got 90k on my 250 and the axles and tranny are still in great shape, even after my occasional beatings i give them.
Old Dec 3, 2007 | 05:03 AM
JOE-M's Avatar
JOE-M
The book said every 100k miles, so that's what I did. That comes out to every three years on mine.
Joe
Old Dec 3, 2007 | 05:17 AM
greythorn3's Avatar
greythorn3
i change mine everytime i go 4 wheeling in water and get water past the axle shaft seal...
Ray
Old Dec 3, 2007 | 06:26 AM
BigJim99's Avatar
BigJim99
Ford Truck Loyalist
The '99 F250SD is the first 3/4 tonner I've ever owned but it's getting the same treatment I've always given my 1/2 tonners--axle and trans lubricant changes every 50,000. I've used nothing but synthetics since they became widely available. Never yet had any trouble.
Old Dec 3, 2007 | 11:05 AM
Flying Finn's Avatar
Flying Finn
I want to change the fron & rear and also the transfer case, what are the best oils for those?
Thanks in advance.
Old Dec 3, 2007 | 08:11 PM
JOE-M's Avatar
JOE-M
The trransfer case is just Merco/Dexron III transmission fluid. Approx 2 quarts. MAKE SURE you can get the top fill plug out before removing the bottom drain plug. If your '03 is the same as my '02 then the front is Hypoid Gear Oil - SAE 90, the rear is SAE 75-140 Synthetic. You will also need some limited slip additive for the rear end.
Joe
Old Dec 4, 2007 | 10:15 AM
Flying Finn
Thanks Joe,
Any favourite brands here?
Old Dec 4, 2007 | 11:53 AM
Eng1Driver's Avatar
Eng1Driver
For the synthetic 75-140 needed in the rear axle look at Mobil1 or Royal Purple as they are very good oils. The front axle is not synthetic so any Castrol, Penzoil, regular Mobil are all fine. Same for the T-case, stick with a name brand ATF.
Old Dec 4, 2007 | 03:03 PM
Flying Finn
Thanks again!
Old Dec 4, 2007 | 05:12 PM
gross30's Avatar
gross30
I had mine changed at 30,000kms when I put a new styling rear diff cover on.
Old Dec 4, 2007 | 05:27 PM
Green Ford's Avatar
Green Ford
Changed mine at 41,000 when I put in new gears and lockers. Royal Purple.
