pump is installed, was able to lift the parts from the old one out with the magnet idea...thanks..bought a magnetic oil drain plug, just in case!!...Anyway, everything is hooked up but not starting...I'm 'figuring' air in line...it was apart for over a week..if that matters??..What's next?...HELP!!....Thanks a unch!!...'89 7.3...
Crank the engine ""15 seconds max"" per time with the fuel header Schrader (tire) valve core removed until fuel is present... replace the valve core. Now crank it again ensuring the FSS is connected on the IP. Note route fuel to a container by hose!!
Do check the fuel hose by the lift pump is not crimped off due to too sharp a bend in the hose..... should be a pigtail Loop.
Also ensure the tank selected has more than 1/4 full......
Did you get this info in the pump box........
This info pertains to Carter #M60278 pump or new long arm style.
WARNING
This fuel pump must be installed only at the low position of actuator cam.
If the pump is installed at any other position than low cam, the pump will be ruined, the engine will stall and damage may result.
Incorrect installation will loosen the pivot pin and allows the pin and lever to come out of the pump and drop into the oil pan. This can occur immediately or after several hundred miles. This type of failure is not covered by warranty.
To ensure that the cam is at low position, it is necessary to use a mirror and a remote starter switch. Observe the cam through the mounting port and bump the engine around until a one (1) inch wide machine surface is observed. This is low position of the cam. Now complete normal fuel pump installation.
9502CA
1991
yes...I am pretty sure I installed it per instructions...bought a mirror and crawled out from under the truck several times until the 'machined inch wide'..came into view....thanks for the help..
