Overdrive
Old Dec 1, 2007 | 03:41 AM
factory594x4's Avatar
factory594x4
Question Overdrive
I am ready to buy an overdrive for my 59' f250 4x4 I6 t-98. Can anyone tell me if it is a np205 t-case? Or what is it. The t-case is mounted in the middle of the frame(divorced from the trans..). So there is a small shaft(about 16") from the trans. to the t-case. Gear vendor says their unit bolts to the rear of the t-case. Won't this make the rear drive shaft too short? How short is too short?
Does any one have any better suggestions? Is there a different unit on the market?
Old Dec 1, 2007 | 04:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Transfer Case = 1959/64 F100/250 = Spicer (Dana) 205
Old Dec 1, 2007 | 07:11 AM
4tl8ford's Avatar
4tl8ford
What are you wanting/expecting from an overdrive in a 4x4 vehicle? 2 wheel drive only? 2/4 wheel drive?
Old Dec 1, 2007 | 01:04 PM
factory594x4
I don't care. It has 4:56 gears And I would like to be able to run on the highway and not lose my off road gearing. I can't go faster than 35mph @4500rpm. Like a DC-10 taching up for takeoff.
Old Dec 3, 2007 | 12:54 AM
idaho211's Avatar
idaho211
Let us know how it works. I am in the same boat with the 4.56 gears on my 60 4x4.
Old Dec 8, 2007 | 01:35 AM
joditruck's Avatar
joditruck
If it is the stock divorced t-case, then it is a spicer 24, not an NP205. Like the NP205 it is gear driven. It would cost you some money, but they make divorced np205's that you might be able to swap in and then add a gear vendors unit to it. Another option would be install 4:10 gears so you motor is not screaming.
Old Dec 8, 2007 | 12:17 PM
F6Guy's Avatar
F6Guy
why not install an NV4500? I am sure some one makes an adapter plus it has to be cheaper than a new t-case and a gear venders unit.
Old Dec 8, 2007 | 01:20 PM
HT32BSX115's Avatar
HT32BSX115
Yeah,
Tell me about low gears! Mine is a 6.80:1 rear.
The Gear vendors unit is a fortune.
My plan is to use an E4OD with a 5.83:1 2 speed axle.
You can get an adapter for just about any trans. I think the one sold by http://www.transmissionadapters.com/ford_y_block.htm might work with a ZF 5 speed.
Cheers,
Rick
