Steering control valve/ball stud
Old Dec 1, 2007 | 02:58 AM
1pump's Avatar
1pump
The power-assist steering in my '76 F250 has a bunch of slop. I was poking around underneath it the other night while a friend was rocking the steering wheel back and forth, and I noticed the slop seems to be in the ball stud at the end of the control valve (it's the Bendix type).
The control valve itself seems to be OK, it's just the ball stud and probably the bushing and seats inside that seem to be worn out.
But I'm having a hard time finding just the ball stud component end of the valve. Control valves complete with the stud are easy to come by, but I don't want to spend $200-$250 on a rebuilt valve if I don't need to.
I found a few places that have rebuild kits for the ball stud, but from what I've read, the stud housing itself might need some machine work, and the kit might be tricky to install. BUT- most rebuilders say things like that to scare people into sending theirs in for a rebuild.
Has anyone here either rebuilt theirs or found a replacement unit? Once again, it's just the ball stud that connects to the pitman arm. It's got the sheet metal clamp thingy around it, and it looks like it comes off the main valve easily enough.
Old Dec 1, 2007 | 06:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D4TZ-3A533-A .. P/S Control Valve Ball Stud Kit ~ 1974/77 F250 4WD-Bendix.
FTE sponsor GREEN SALES has 6 Ford NOS kits in stock (800-543-4959)
Old Jan 20, 2010 | 06:08 AM
73'Hiboy's Avatar
73'Hiboy
Hi folks, I'm new to the site. I have the same problem with my 73 F250 that I just purchased. I'm told it's a Bendix unit as well since my truck ser# is after 80,001.
I noticed Bill that you have part# D4TZ-3A533-A listed as a repair kit.....will this work for my truck as well?
Many Thanks - Cool site!
Rob
Old Jan 20, 2010 | 06:20 AM
brownfoot's Avatar
brownfoot
did you have the truck running?
there is a spool valve in the control body that may be moving and showing there is slop
the ball has to be worn pretty/damaged bad to need replacement and there is some adjustment to tighten.
the end of the drag link where it attaches to the spindle is the same as a tie rod end, that is where most of the play in my steering was, of course that link is pricey too even if you can still buy that piece without the control valve attached.
Old Jan 20, 2010 | 12:10 PM
montana_highboy's Avatar
montana_highboy
You have the Bendix c/v then, DC has the ball stud kits for 50 bucks.
Old Jan 20, 2010 | 04:31 PM
NumberDummy
No, it's in-correct.
IF you have a 1973 F250 4WD, you do not have BENDIX Power Assist P/S.
The T80,001 serial number only applies to 1974 F250 4WD's.
ALL 1973's, 1974's before serial number T80,001 use GARRISON Power Assist P/S.
1974's from serial number T80,001, 1975/77's use BENDIX Power Assist P/S.
See your other thread for the correct info, and the correct part numbers.
Old Jan 20, 2010 | 06:38 PM
73'Hiboy's Avatar
73'Hiboy
Thanks all, it would seem I have my wires crossed somewhere. I'll check it out and let you know what I end up with. It definetly has the ball stud though which makes it a Bendix right?, and the title for the truck is has it as a 73. I'll let you know how I make out.
Rob
Old Jan 20, 2010 | 08:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Check the frame VIN number, it's located on the top right frame rail about inline with the alternator. If you have the Garrison style there are two ends, 1 front and 1 rear. Here are the p/n's for them:
73-74 F250 4WD & p. steering before s/n T80,001
D3TZ-3404-D front 3 1/2" long 3/4"-16 female thread
D3TZ-3404-F rear 5 1/2" long 7/8"-18 male thread
Old Jan 21, 2010 | 01:30 AM
NumberDummy
The OP has TWO different threads on this subject.
I listed these same (draglink) part numbers and the sources who have them in his other thread.
The OP still insists he has a ball stud. I wonder if he really knows what a ball stud is.
A picture is worth a 1000 words: Illustration Section 36, Page 11 shows both the Garrison and Bendix systems.
Old Jan 21, 2010 | 02:11 AM
mikeo0o0o0's Avatar
mikeo0o0o0
'nuff said Bill, here it is.
File Type: pdf
Old Jan 21, 2010 | 02:34 AM
TexasTrash's Avatar
TexasTrash
I have the same problme with my 75 F-100, is that the same part I need?
Old Jan 22, 2010 | 11:14 AM
73'Hiboy's Avatar
73'Hiboy
Hey, thanks for the frame vin# location Mike - I'll check it out and let you know.
I couldn't open the above attachment for some reason so I found this to help show what I have.....(link - Ford Truck Power Steering Control Valves & Cylinders). The one on my truck is the righthand bottom of the page, a Bendix......
Also, I apologise for the two threads - as I mentioned in one of them I'm new at this forum stuff so I hope I didn't put anyone out.
Cheers
Old Jan 22, 2010 | 11:43 AM
montana_highboy
You definitely have the Bendix unit, here's a better picture for you...http://www.stangerssite.com/TruckCVparts.html
Old Jan 22, 2010 | 02:19 PM
NumberDummy
D4TZ3A533A .. Ball Stud Repair Kit / Obsolete
Last MSRP: $82.57 / Actual Ford Dealer net cost: $49.48
Fits: 1974/77 F250 4WD (High Boys) w/Bendix Power Assist P/S.
DOTTS MOTOR CO. in Clearfield PA has ONE = 814-765-9681.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606=787-5293.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
GREEN SALES CO. in Cincinnati OH has EIGHT = 800-543-4959.
Originally Posted by Texas Trash
I have the same problem with my 75 F100, is that the same part I need?
ALL 1973/77 F100/150 4WD's used Garrison Power Assist P/S.
The Garrison system uses two draglinks, one on either side of the control valve / Click on the link in Post #8 to see the Garrison control valve.
The F100/150 draglinks are not the same as the two 1973/74 F250 draglinks used with Garrison P/S.
The 1973/75 F100/150 4WD draglinks are not the same as the 1976/77 F100/150 4WD draglinks.
The following draglinks fit: 1973/75 F100 4WD & 1975 F150 4WD / Both with Garrison Power Assist P/S
D3TZ3304C .. Draglink / 17" long / 7/8" -18 male threads / Obsolete
LUCAS MOTOR CO. in Lucas KS has ONE = 785-525-7778.
KOEHN MOTORS in Wellington KS has ONE = 620-326-5915.
GRIFFEN FORD-MERCURY in Louisburg NC has ONE = 919-496-4169.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
BOWMAN SALES & SERVICE in Bowman ND has TWO = 701-523-3257.
GREEN SALES CO. in Cincinnati OH has SIX = 800-543-4959.
D3TZ3304E .. Draglink / 9 3/16" long / 3/4" -18 female threads / Obsolete
WICKER FORD in Ticonderoga NY has ONE = 518-585-2888.
BOWMAN SALES & SERVICE has ONE.
GREEN SALES CO. has TWO.
n9lhm
Dec 7, 2014 10:03 AM
77429highboy
Jun 22, 2013 11:02 AM
montana_highboy
Jun 15, 2013 03:10 PM
banjopicker66
24
Apr 8, 2013 11:49 AM
Snowseeker
Jun 20, 2012 09:32 PM
