Offenhauser dp
Old Nov 11, 2001 | 09:21 AM
bilsoft's Avatar
bilsoft
Offenhauser dp
After reading many posts about the carb placement on the DP manifold I think I may have mine wrong. I have the linkage side of my Holly 390 4 barrel facing the valve cover. Is this right? I have noticed the idle screws do have to be adjusted differently for each side but other than that it seems to run alright. Don't tell me it can get better. Also I'm going to change to Eldelbrocks emission legal carb for two reasons one is I am in Mesa AZ and emmisions are required (need a place to hook all the junk up to look good) and the other reason is the fuel we have to burn here screws the rubber up in Hollys (as they have admited) and I'm tired of changing carbs rvery six months. The smallest Eldelbrock (street legal) is a 600 cfm is this going to be a problem?
'81 F-100 SB
300 hd
4.11 rear end
4 speed od
headers
Jacobs
ele. fan
lift
Old Nov 11, 2001 | 11:22 PM
vic_rattlehead's Avatar
vic_rattlehead
Offenhauser dp
When I did my setup (clifford and a 390 holly). I placed my carb so that the two primaries are up front (closest to the valve couver). This way, the front of the engine will get the same amount of gas as the back. This link has a diagram, and more info.
[link:www.inliners.org/tech/tech7.html|Inline 4bbl Carb Placement].
Hope this helps
Chris
Old Nov 14, 2001 | 07:54 PM
bilsoft's Avatar
bilsoft
Offenhauser dp
Thanks for the info. Looks like I got a job to do this weekend.
Old Nov 15, 2001 | 09:57 AM
whittey's Avatar
whittey
Offenhauser dp
Hrm, i'd put primaries away from the VC as the longer intake path may possibly help out your lowend. Thats the way I currently have my Edelbrock 500cfm Vacuum secondary carb. Sure it has a mech choke, but you can get the $25 kit to convert to electrical ;o
-=Whittey=-
Old Nov 15, 2001 | 11:53 AM
jwtaylor's Avatar
jwtaylor
Offenhauser dp
aearch
Nov 23, 2012 10:46 PM
Riderman
34
Jan 11, 2010 11:01 AM
FXSTC
Arizona Chapter
19
Nov 30, 2002 04:27 PM
BigBronco93
Aug 16, 2001 07:37 AM
BigBronco93
1978 - 1996 Big Bronco
Aug 9, 2001 02:41 PM
