Anyone know how to get a old rear-view mirror nub off the windshield?? My ford f250 has no r.v.m., just the nub, which is not the same as the new one i am putting on. Help!
Hook a tow chain to it, but be real easy when you pull it. Just kiddin. There's gotta be something at an auto parts store that can dissolve the glue holding it. Worth checking into if you haven't already.
I'd follow Dan's advice. Head the window from the outside (warmer inside) and try to heat it VERY SLOWLY if you're in a cold climate (who isn't this time of year). If it's really cold outside and you heat the window too quickly the glass will expand unevenly and crack. Heck you could even throw a solvent into the mix and use all three! Heat, solvent, putty knife
I've seen window installers grab em with pliers and twist em to get them off the old window to move it to the new one. Didn't seam to hurt the window none, could try that first just go easy. If it don't come off heat it up and try again.
And yea like Chris said don't shock the glass to suddenly with the heat, turn the defrost on high until the glass is warm to start with.
I'd heat the metal from the inside once the glass is warm, it will hold the heat better than the glass will, just let the flame from a lighter lick on it. Shouldn't take much.
from my inner 13-year-old mind: read above posts and replace "windshield" "mirror" and "glass" with dirty words. ....would make a good one of those fill-in-the blank games
Allow me to assist you Tom...
Today's Mad Lib:
I've seen _______ installers grab em with pliers and twist em to get them off the old _______ to move it to the new one. Didn't seam to hurt the _______ none, could try that first just go easy. If it don't come off heat it up and try again.
And yea like Chris said don't shock the _______ to suddenly with the heat, turn the defrost on high until the _______ is warm to start with.
I'd heat the _______ from the inside once the _______ is warm, it will hold the heat better than the _______ will, just let the flame from a _______ lick on it. Shouldn't take much.
Anyone know how to get a old ______ nub off? My ______has no ______, just the nub, which is not the same as the new one i am putting on.
Hook a tow chain to it, but be real easy when you pull it. There's gotta be something at a ______ store that can ______ the ______ holding it. Worth checking into if you haven't already.
I'd follow Dan's advice. ______ the ______ from the outside (warmer inside) and try to heat it VERY SLOWLY if you're in a cold climate (who isn't this time of year). If it's really cold outside and you heat the ______ too quickly the ______ will expand unevenly and crack. Heck you could even throw a solvent into the mix and use all three! Heat, solvent, ______knife
You could skip the possibility of breaking the windshield, and just glue the new mount to the old one. If it ever detaches itself from the windshield, you can put the two mounts in a vise and use a small chisel to seperate them. That is what I ended up doing. Worked fine.
Good Luck
Frank
Well Unless you posting from top the nearest Mountain . I bet you are not dressed in Carhart Gear.
