HPOP lines leaking....
Old Nov 30, 2007 | 10:47 AM
mongo75's Avatar
mongo75
Does Ford sell the O-ring that goes between the HPOP itself, and the fitting that attaches to the high pressure line? Or is it an O-ring I can get locally? I know I changed one before with a plain-Jane o-ring I had, but I can't remember if the one leaking is the same one I changed before so therefore I don't know if it has to be special or not.
Old Nov 30, 2007 | 11:27 AM
SolidGround's Avatar
SolidGround
Viton... that's the material you're after.
Get 'Viton O-rings'
Anywhere you can get o-rings, you should be able to get theses.
i.e. NAPA Vatozone O'Reallys
Old Nov 30, 2007 | 12:38 PM
mongo75's Avatar
mongo75
Thanks Jet, that's what I was thinking. I forgot what size it is, are they #5?
Old Nov 30, 2007 | 01:17 PM
clux's Avatar
clux
They're a #6 ORB, 90 durometer.
Old Nov 30, 2007 | 02:49 PM
mongo75's Avatar
mongo75
Thanks Clux
