i jus got my truck back from the dealership cause it wouldnt start...well they replaced the hpop and inj. reg. well the next i was driving to work and it just truned off on me again....well it started right back up...so i took it back to the dealership and they checked the dip stick and there was no oil(reason for it turning off)well i looked at the degas bottle and seen t over flowing....i just put a new oil cooler and egr cooler and it just got new heads about 6 months ago...well my question is there any way they could have messed thing up to cause it to do this again cause they are trying to same its my fault for putting the oil cooler in myself....it never lose oil till i took it to them .......sorry for the long story.....
Did you put the oil cooler in before or after they replaced the HPOP? If after, I don't see how you're going to be able to hold them responsible for it since the new cooler was apparently defective. If before, they should have seen the bad oil cooler (assuming it was bad at that point) when they installed the new HPOP. Either way it doesn't look good unless you can somehow prove they are responsible for the leaking oil cooler.
i put the oil cooler in 3 months before they but the hpop in... i never had a problem losing oil until i got it back from them...and how do you lose that much oil with in a day....
what i dont undrestand is how that could have happened....i just drop 2k to get it fix from the dealership well they got it started and the next day im out of oil???? im so lost....i mean like i said the oil cooler is brand new i installed it myself.....it neverd overheated never low on oil?????maybe im looking for a way out i dont know....But when you drop that kind of money you would think you would get a truck that is fixed,right???
but thats just it i bought the oil cooler and put it in myself....also another thing it had turbo fart eveytime i let go of the gas (not on hard acc.)...they called me in yesterday and told me i was better off buyin a whole new engine....what the F**k...
but i bought the oil cooler from an individual that didnt need it do to something else....would over boosting cause the oil to shoot out of the degas bottle?????
Oh, that would be different. It sounds like you may have gotten taken.
Is the coolant/oil really clumpy? If it is really bad, that may be why the dealership told you that you need an engine. It can be nearly impossible to flush all of that stuff out of the engine, radiator, heater core, egr cooler, etc...
