Rusting front spring perch
Old Nov 30, 2007 | 07:15 AM
oldstylefseries's Avatar
oldstylefseries
Hey fellas,
Been a while since I've been here. I was under my truck (95 F-150, 2wd). I bought this truck new and it has spent it's entire life here in the salt/rust belt. I was under it the other day, and was looking at the FRONT spring perches. They LOOK rusty, and I can chip some chunks off of them. I was just wondering if anybody else has ever had to replace these perches due to rust.
THanks in advance.
Old Nov 30, 2007 | 09:57 AM
F150xlt's Avatar
F150xlt
Jeffs Bronco Graveyard sells replacement coil spring towers.
They sell one that has mounting for dual shocks but will still work for trucks that only have a single shock.
I believe the spring towers are held on by some bolts and rivets.
Click on the link below.
http://broncograveyard.com/bronco/i-...uble_shock.htm
Old Nov 30, 2007 | 01:37 PM
alz's Avatar
alz
Check the dealer. I purchased mine from BroncoGraveyard only because I wanted it ASAP, they are local to me. The local dealer was actually cheaper.
Old Dec 1, 2007 | 11:56 AM
lostin90s's Avatar
lostin90s
Yes I have heard of several swaps or patches. I wash mine well every thaw and remove any loose piant. The parts truck I just got rid of they were fine. But yep salts fun isn't it.
Old Dec 3, 2007 | 01:11 PM
aj197816134's Avatar
aj197816134
Salt will eat them, check up on the top. I just posted about them in another post. They arent hard to do.. Need a way to cut and chisel out the rivits, clean up the frame in that area. Get some Grade 8 bolts, nuts and flat washers and go to town. Takes a little over and hour sometimes a lil more but not bad at all to do...
racerjmm33
Sep 12, 2014 10:19 PM
Steve
Jan 25, 2014 09:37 AM
Shoveldog
1983 - 2012 Ranger & B-Series
Mar 8, 2008 10:23 AM
KJKozak2
May 24, 2004 04:40 PM
KJKozak2
Oct 8, 2003 05:20 PM
