dumb rivet question
Rivet Type <table cellpadding="0" cellspacing="0"> <tbody><tr> <td>Images of Installed: Blind Rivets | Solid Rivets | Push-In Rivets | Split, Tubular, or Press-Fit Rivets | Rivet Nuts | Panel Screws | Bolt-Type Rivets
</td> </tr> </tbody></table> <table class="TableImgTopImg" cellpadding="0" cellspacing="0"><tbody><tr> <td class="TableImgTopCellImg" onmouseover="javascript:this.className = 'TableImgTopCellImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellImg';" onclick="javascript
arent.location = './psearch.asp?FAM=rivets&FT_5722=241001&session=rive ts;5722=241001';" align="center" valign="top" width="25%">
Blind
</td> <td class="TableImgTopCellImg" onmouseover="javascript:this.className = 'TableImgTopCellImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellImg';" onclick="javascript
arent.location = './psearch.asp?FAM=rivets&FT_5722=241002&session=rive ts;5722=241002';" align="center" valign="top" width="25%">
Solid
arent.location = './psearch.asp?FAM=rivets&FT_5722=241003&session=rive ts;5722=241003';" align="center" valign="top" width="25%">
Push-In
arent.location = './psearch.asp?FAM=rivets&FT_5722=241373&session=rive ts;5722=241373';" align="center" valign="top" width="25%">
</td> </tr> <tr> <td class="TableImgTopCellImg" onmouseover="javascript:this.className = 'TableImgTopCellImgHL';" onmouseout="javascript:this.className = 'TableImgTopCellImg';" onclick="javascript
arent.location = './psearch.asp?FAM=rivets&FT_5722=240073&session=rive ts;5722=240073';" align="center" valign="top" width="25%">
Rivet Nut
arent.location = './psearch.asp?FAM=rivets&FT_5722=235213&session=rive ts;5722=235213';" align="center" valign="top" width="25%">
Panel Screw
arent.location = './psearch.asp?FAM=rivets&FT_5722=241005&session=rive ts;5722=241005';" align="center" valign="top" width="25%">
Bolt-Type
</td> <td class="TableImgTopCellImg" style="border-right: 0px none; border-bottom: 0px none;" align="center" width="25%"> </td></tr></tbody></table>
On the bed there are steel brackets on the outside of the rear bed rail. These are rusty and make it hard to protect and access the bottom of the rear panel. I'm removing them cleaning everything up and re-attaching...
Bigger rivets will be a great help...the spot welds have got to go.
Ford use to use a drive rivet that was a 1/4".
Or move over to the threaded inserts and use machine screws.
I'm not sure of the thickness but it's heavy dut steel not panel steel.
