Starter won't quit
Old Nov 29, 2007 | 05:01 PM
glsweet's Avatar
glsweet
Starter won't quit
97 Ford F250 .When try to start truck the starter stays running after the truck starts. I can unhook the battery cable to make it stop or keep turning the key off and on and it will finally stop. Here is what I have done: Replace the selenoid on the firewall. Replaced the ignition switch under the dash. Still have the dash tore apart. I can take the key cylinder out and put a screwdriver in and start the truck and it does the same thing. sticks. What am I missing here?
Old Nov 29, 2007 | 05:40 PM
Franklin2's Avatar
Franklin2
When it sticks, pull the small wire off the solenoid under the hood(red/blue). This will verify if you are getting an unwanted signal to energize the solenoid, or the solenoid contacts are actually welding themselves inside. Some of the new solenoids are not very high quality, and there has been more than one person on here put a new solenoid on, and have this problem.
Old Nov 29, 2007 | 07:51 PM
glsweet's Avatar
glsweet
Thanks Dave, I will try that in the morning. I have learned a lot from this site. Hope I can add something too sometimes.
Old Nov 29, 2007 | 09:30 PM
Gevans17's Avatar
Gevans17
Cool Starter keeps running
Had same thing happen on an 89 Aerostar. Ended up replacing the starter. It was a recently rebuilt one from AZ. Boy that thing made quite a racket!
