OBDII Code P1409
Old Oct 9, 2023 | 12:06 PM
Bexar_County_Grouch's Avatar
Bexar_County_Grouch
Trailering
Originally Posted by Silver Streak
What projectSHO89 said. OBD2 is smart enough to know the difference between a mechanical fault and an electrical fault. If you have a circuit code for the EVR solenoid there are only 4 possible causes: a bad EVR solenoid, a bad computer, open or short in the EVR power wire, open or short in the EVR ground wire.
I know asking a question on this ancient thread is probably not going to work, but does anyone know what to do if the issue is an open/short in the EVR power or ground wire? What is the repair process? I've had this issue and replaced all components, but still get the p1409 code. Rough idle. I'd like to just remove the EGR system completely, but don't know if it'll work since this is an electrical fault and not a mechanical...
craigdallen
32
Oct 13, 2014 05:28 PM
scrobbie
28
Jan 30, 2014 08:52 PM
a_frenchswallow
Oct 29, 2010 05:10 PM
joycat1
Modular V8 (4.6L, 5.4L)
Jan 26, 2004 12:02 AM
crazy_goodolboy
Jun 16, 2001 05:11 PM
