carb help
Old Nov 29, 2007 | 11:52 AM
marioc956's Avatar
marioc956
carb help
I have a holley 600 4160 im having problems starting my truck it will turn on then die on me right away i have to give it a couple of pumps then it will turn on but i have to leave the gas pressed a little what can cause this problem. Also when it shifts into 3rd gear my truck boggs down the truck has a 302 electric fuel pump with 6psi going into the carb i adjusted my needles and seats so fuel level is fine what else can i check.
Old Nov 30, 2007 | 05:34 AM
LxMan1's Avatar
LxMan1
Sounds like it's running lean. Vacuum leak? needs larger jets? fuel filter dirty?
What is the list# on the carb?
Old Nov 30, 2007 | 07:56 PM
Putt's Avatar
Putt
Start up issue might be choke problem.
Old Nov 30, 2007 | 10:41 PM
kermmydog's Avatar
kermmydog
Are your idle mixture screws set correct? Is it a reverse idle carb?
Old Dec 1, 2007 | 10:20 AM
Putt's Avatar
Putt
A list number from the carb might be helpful!
Schickel
Jul 22, 2012 09:26 PM
Imdok
Nov 27, 2009 04:19 PM
735.0Short
Nov 23, 2006 05:35 PM
Green Streak
Nov 7, 2004 03:04 PM
Pigsticker
Dec 30, 2002 09:47 PM
