vacuum problem
Old May 13, 2008 | 10:33 PM
Dave Sponaugle's Avatar
Dave Sponaugle
luthrebediesel,
Welcome to FTE and the IDI forum.
I am going to stay silent, I know very little about automatics.
We have several users here that are good with them though, they should be along shortly.
Old May 13, 2008 | 11:14 PM
David85's Avatar
David85
Originally Posted by luthrobediesel
How does a VRV work. I know that the modulator valve has to have vacuum on it at all times unless ur getting on it. So if one side of the VRV has supply and one goes to the mv, even when ur getting on it its still gonna have vacuum when u open her up cause theres no where for the vacuum to go. If the VRV is completely at rest should vacuum be able to flow through it? Im working on a truck with the same problem. If i floor it it changes like ur just tooling around but when i too; around it winds up. WTF?
The way its supposed to work is to apply high vacuum for light load and low vaccum for high loads. The idea is that if there is a complete vacuum system failure, the transmission will revert to high line pressure instead of low line pressure (high pressure being the lesser of the two evils). It almost sounds like two vacuum lines may be reversed. When did this first happen? Has any recent work been done on the truck?
Old May 14, 2008 | 07:49 PM
luthrobediesel's Avatar
luthrobediesel
I completely rebuilt the engine. I removed the engine and had the block sleved. After examining the vrv closely i saw that it was labeled trans and vac and i did have it right. When i tore it down to rebuild it i just took the ip off and laid it in the back and never adjusted anything. Why does the diesel c6 also have that rod on the kickdown i thought if you lost enough vacuum it would kickdown anyways. Its a retired uhaul if that helps. U haul does some weird stuff.
Old May 14, 2008 | 09:15 PM
David85's Avatar
David85
The kickdown rod and the VRV operate independently, no connection except through the throttle linkage. Vacuum failure has no effect on the operation of the kickdown rod. I never used the kickdown rod with my driving style, and have heard of some simply disabling it altogether. Normally the VRV is quite effective at timing the shifting.
From what you are saying, the truck has done this since you got it, correct?
Have you inspected the inside of the vacuum line from the transmission to see if there is ATF in there?
Have you checked the vacuum system to make sure you have enough vacuum? lack of power brakes, for example, could indicate low vacuum.
Old May 16, 2008 | 05:22 PM
luthrobediesel
im going to test it tomorrow according to james and see whats going on. Ill be testing the vacuum pump output and the vrv output. I got a pump and a gauge from oreillys today maybe their cheap crap will work right. oh and now it hasnt done this all along just after the rebuild
Old May 16, 2008 | 08:21 PM
Dave Sponaugle
You may have a resevoir that looks like the black ball at the right side of the yellow circle in this picture.
JeepScrambler
Oct 24, 2014 10:18 AM
nvrsadi
Jul 4, 2014 02:59 AM
ky_ace
Apr 13, 2014 06:53 PM
DBGrif91
19
Aug 11, 2013 07:31 AM
