Leveling Kit From Factory?
Old Nov 29, 2007 | 07:06 AM
krazymatt's Avatar
krazymatt
I have a 2006 4x4 SuperCrew Lariat with 18" Tires and wheels and I can swear that this truck came from the factory with a leveling kit. It sits pretty nice and level. Is this possible or am I imagining this?
Old Nov 29, 2007 | 08:23 AM
mrpositraction's Avatar
mrpositraction
Look at the top of the struts, are there blocks on top? You can see mine (after market) just from looking at the side of it.
Old Nov 29, 2007 | 08:33 AM
mattd17's Avatar
mattd17
what size are your rear blocks? my 4x4 screw had 2" stock blocks.... just something else to check out.
Old Nov 29, 2007 | 12:29 PM
MBBFord's Avatar
MBBFord
Measure the wheel wells front and rear. If there is abouta 2" difference, then it isn't level.
Got any pics?
I doubt that any came from the factory leveled, but who knows what Ford does........
Old Nov 29, 2007 | 12:33 PM
HuntnFordMan's Avatar
HuntnFordMan
Why do I need a leveling kit to put bigger tires on? if the truck sits fine now with stock BFG Tires, and I buy BFG tires that are bigger, shouldnt the truck sit just like it does now only higher?
I have anways been confused by this. All 4 tires now are the same size so I should be able to change that size and as long as all 4 stay the same the truck should sit the same. Hmmmm the things my logic thinks through...
Old Nov 29, 2007 | 02:29 PM
builtfordtough13's Avatar
builtfordtough13
Could the dealer of leveled it out? I have seen some dealers that do this/
Old Nov 29, 2007 | 02:48 PM
MBBFord's Avatar
MBBFord
That would be the only possible explination I can think of if the truck was new, and is actually level.
Old Nov 29, 2007 | 03:58 PM
riored4v's Avatar
riored4v
same here.
I know ALOT of dealers around here do that on quite of a few of their trucks.
Old Nov 29, 2007 | 04:00 PM
mrpositraction
It is for appearance and fitting larger front tires on than would normally fit with out. Yes you can go bigger at factory height, but you can go even bigger at a higher height. Not sure why you mentioned 4 tires being the same height, I think you are confused.
Old Nov 29, 2007 | 04:10 PM
black04lariat's Avatar
black04lariat
That would be my guess. The dealers around here throw 6inchers on and 35s and overcharge out the yang for it.
Old Nov 29, 2007 | 09:11 PM
krazymatt's Avatar
krazymatt
Thanks guys, I haven't actually measured the space from the top of the tire to the fender well opening. My truck sits decently nice, but I wouldn't mind it a little higher all around when it's time for tires and maybe go up a size in tires.
Old Nov 30, 2007 | 01:31 PM
jstnromero's Avatar
jstnromero
ya I saw a dealer in San Diego that was offering a six inch lift, 35's, and moto metal wheels for 7000.....stealerships....says it all
Old Nov 30, 2007 | 07:37 PM
deisele75's Avatar
deisele75
Because you don't wan't your tires rubbing when you turn or hit a bump.
Old Dec 1, 2007 | 09:22 PM
Ryan50hrl's Avatar
Ryan50hrl
ya know...my lariat sits more level than my xlt ever did....right from the factory....but i've never looked into it....
Old Dec 3, 2007 | 11:14 PM
krazymatt's Avatar
krazymatt
Okay I finally measured the clearance from the top of the tire to the top of the fender arch, and it is like 2 inches plus less on the front. I did measure the rear blocks while I was rotating my tires this weekend, and found that they are 2 inch blocks. So what would I need to level the truck, 2.5 inch front leveler kit? Also I'm assuming I'll need an alignment? Is it more difficult to align with the level kit up front? If I need to align it, I'll just wait till it's time to replace my tires. Thanks in advance.
