Sponsored by: Real Truck
Exhaust Manifold
Old Nov 29, 2007 | 06:33 AM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
Exhaust Manifold
Well I got 2 exhaust manifolds off ebay for $9 and $20 to ship them. No cracks or holes. I changed the one on the passenger side because there was a hole in it. Well it was more then a hole lol. I am surprised it didnt crack in half. Now the truck runs excellent and sounds even better. Just wanted to show yall the crack/hole.
Old Nov 29, 2007 | 07:06 AM
Toyman's Avatar
Toyman
How long did it take you to change the manifold? My 99 has a little tick that goes away when it gets warm, but I know I'm going to have to change it soon.
Thanks Toyman
Old Nov 29, 2007 | 01:42 PM
hydro_37's Avatar
hydro_37
Thanks Toyman
I would check the manifold bolts first. There may be one or more broken causing the "ticking" you are hearing.
Old Nov 29, 2007 | 01:56 PM
EaTmYtAiLpIpEs
Well between the idiot that did the head gaskets putting the old bolts and nuts back in. At 10 of 5 I had to run up to a ford dealer to gets the studs which cost me $26 fot the studs and nuts. It took me about 3 1/2 hours because there is so much you have to fight. I left the tire on. Just have to that off the wheel well which is a pain in the ***.
Old Nov 29, 2007 | 07:25 PM
Toyman's Avatar
Toyman
If there was a broken bolt, would the noise go away after everything got warm? I'm thinking it's warped just enough to make noise until the head expands from the heat (just guessing).
Toyman
Old Nov 30, 2007 | 12:48 AM
WildWildWest's Avatar
WildWildWest
Toyman
Could also be a donut - replaced one on mine to stop the ticking - cheaper yet!!
Old Dec 14, 2007 | 09:43 PM
wll's Avatar
wll
im wondering what will be the best way to go about fixing my manifold problem. it just got very loud. power cut in half,cab fill with fumes,truck runs like chit. im very straped fo funds. im a tree climber and need my truck daily to get to work. i still owe money on it and my trans is acting up. what kind of money am i looking at? is it better to use hedders or it dont matter? if its only 1 side should i not bother with the other? im looking for cheap good fix.please help
Old Dec 14, 2007 | 09:54 PM
Izzy351's Avatar
Izzy351
Which engine is in your truck?
Old Dec 14, 2007 | 10:54 PM
wll's Avatar
wll
5.4l 4x4 auto
5.4 4x4 auto
Old Dec 14, 2007 | 11:31 PM
Izzy351's Avatar
Izzy351
5.4 4x4 auto
hhmmm... Can't help you. 5.4 guys??
Old Dec 15, 2007 | 11:58 AM
wll's Avatar
wll
please
is this a expensive job? about how much $? i know there are a few vairables but is there any thing i can do to make it less costly? will my insurance cover this? are s/s nuts and bolts better than steel for this application? are my heeds alluminum? 99 f150 5.4L 4x4 auto
