AOD Tranny issues
Old Nov 29, 2007 | 12:03 AM
85DougF150's Avatar
85DougF150
AOD Tranny issues
I have a 85 f150 ext 4x4, with an AOD tranny, The problem is, when im driving along its goes threw each gear fine, but when it shifts into O/D, the motor seems to work harder (bogging) and i start to loose road speed, until it shifts down to 3rd, has anyone had this sorta problem ?
Old Nov 29, 2007 | 11:58 AM
Franklin2's Avatar
Franklin2
Sounds like the tranny is working, and there is either something wrong with the engine, or you have put oversize tires on it.
Old Dec 1, 2007 | 05:31 PM
scottddove's Avatar
scottddove
unfortunately that is the way it is. the aod is just not much good in these trucks. I dont know if the truck is just to heavy or what but I have kicked my self may times for spending 2500 dollars for replacing mine in my 86 and not just getting a c-6 and putting it in.
Old Dec 2, 2007 | 01:38 PM
Sport45's Avatar
Sport45
You could try adjusting the TV cable or rod a tiny bit longer. That might delay the shift to OD enough to let the engine have enough rpm to hold it in gear. Don't get carried away with the adjustment as a little goes a long way.
Old Dec 3, 2007 | 08:27 AM
Boss50's Avatar
Boss50
The OD clutches in AODs aren't built very good. I believe the fix is a new servo piston with an o-ring on the shaft to seal off the fluid. I got mine from Sonax relatively cheap. OD works fine
Old Dec 3, 2007 | 08:52 AM
Conanski's Avatar
Conanski
Is this a new problem or has it always done it? What motor and gearing are in the truck? Tire size?
Old Dec 3, 2007 | 09:28 AM
Retiredfire's Avatar
Retiredfire
Red face Codes &ID Plates
Anyone have the Codes & I D for Tran. Axles for 1980- 1986 Trucks.
Old Dec 3, 2007 | 10:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Codes: Do you mean the Ford ID numbers?
There are different codes for each type of auto trans.
Prefix: PJA, PGB, PKB etc.
The Suffix leads to a particular year the transmission was used.
Example: PKB-A33 = 1985 F150 302 w/AOD.
Which rear axles? There are several.
btw: There are dozens upon dozens of codes for both axles and transmissions.
Listing them all will take hours of lookin' 'n typin'....
If you want a specific year and type of trans & rear axle, that will be a might easier.
Old Dec 3, 2007 | 11:45 PM
85DougF150's Avatar
85DougF150
Thumbs up Tranny Issue
Anyways yeah im slowly getting it, when i bought the truck from a guy a while back, and he didnt now much about them, he set the timing up a 0 degrees, i advanced it to 10 degrees now, it runs a hell of alot better now. plus i found a slightly small vacum leak on the rightside inner fender, cured that and it shifts pretty fine now other than the 31" tires that throw it off a lil now.
thanks everyone for all the info and thoughts.
Doug
Old Dec 4, 2007 | 08:25 AM
blue beast's Avatar
blue beast
The internals from the improved later trannies can mostly be put into the AOD so
the strengths will be on par with the supposed newer better trannies.
http://www.lincolnsonline.com/tech/00080.html and check baumann for parts and
other tips.
jpeckham
Aug 30, 2014 07:05 PM
jpeckham
Mar 11, 2013 02:12 AM
Poison Oil Racing
Jul 14, 2009 02:07 PM
onioncasserole
Oct 18, 2007 07:39 AM
Torque1st
Sep 17, 2002 09:28 PM
