1999 diesel engine stops running
Old 11-28-2007, 07:59 PM
dlbrooks2658's Avatar
dlbrooks2658
dlbrooks2658 is offline
Started truck and let it warm up, engine shut off, restarted right away, did it again a few minutes later. Once on the road no issues with running but service engine light is on solid now.
Old 11-28-2007, 08:34 PM
badger2196's Avatar
badger2196
badger2196 is offline
Sounds like the classic CPS issue. If you replace it, make sure you get the new (cheaper and better) gray CPS.
Old 11-28-2007, 09:28 PM
Clint40's Avatar
Clint40
Clint40 is offline
Cps it could be OR the UVC harness is apart.
Old 11-28-2007, 09:49 PM
dlbrooks2658
installed a brand new CPS last week
Old 11-28-2007, 10:08 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
You really need to have your faults codes read with a scanner compatiable to our powerstroke.. When the SES light is on, does the engine miss like it is running on less than 8 cylinders? This would indicate under the valve cover wiring or connector is bad or loose.. Did you get a new cps from ford or aftermarket?
Old 11-29-2007, 10:10 AM
dlbrooks2658
New CPS from Napa Auto. Engine running on all 8 - plenty of power, just stops like the fuel is shut off when at idle. After driving the truck for 1/2 hour engine no longer shutting off at idle.
Old 11-29-2007, 10:18 AM
TurtleRacing's Avatar
TurtleRacing
TurtleRacing is offline
PSD Addict
There have been a few complaints about CPS from Napa. Might look into that.
Old 11-29-2007, 03:27 PM
WonderDonkey's Avatar
WonderDonkey
WonderDonkey is offline
Napa CPS = Pile of crap, you may have a bad connection on your UVC.
Old 11-29-2007, 06:49 PM
badger2196's Avatar
badger2196
My first CPS replacement was the NAPA component and it died after less than 100 miles.
Old 11-30-2007, 12:05 AM
dlbrooks2658
here are the DTC codes -
#01 - P1211 - ICP Not Controllable
#02 - P0344 - CPS intermittent bank 1/1
#03 - P0603- Internal Ctrl Mod KAM Error
does replacing the piece of crap Napa CPS with the part from Ford fix this?
Old 11-30-2007, 01:31 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
Pretty much. Nothing worse than a POS.
Old 11-30-2007, 08:51 AM
dlbrooks2658
thanks again for everyones help. this forum is great...
Old 12-01-2007, 09:12 AM
pminne's Avatar
pminne
pminne is offline
Rocky Mountain High
Where is the CPS located?
Old 12-01-2007, 10:50 AM
motionmarineaudio's Avatar
motionmarineaudio
motionmarineaudio is offline
no smoke out of exhaust while cranking. the question is fuel or spark. would there be any codes to check for. could my diablo predator programmer tell me any codes?
Old 12-01-2007, 11:22 AM
clintbonnie
The cps is located on the front of the engine..You can see it if you crawl under the engine, on pass. side front, above the main pulley and near the water pump you will see it.. There is a metal angle bracket attached to the sensor and it is held in with a 10 mm bolt. After removing the bolt, just pry the sensor out, after removing the electrical connector. For more info (bookmark this link) see:
http://www.7point3.com/mods.aspx
The sensor p/n's in the above link are out dated.. Go to Ford and get a F7TZ-12K073-B. It is Grey in color.. Should be less than $30.
Quick Reply: 1999 diesel engine stops running
