Tires Cupping
Old Nov 28, 2007 | 06:28 PM
JRStraight's Avatar
JRStraight
Tires Cupping
Has anyone run into problems with their tires cupping? Mine started about 2 months ago. I found the ball joints were shot and replaced them, alignment, rotated the tires, blah blah... Now, the good ones, are starting to cup as well. I just jacked it up and checked everything, it's all tight. Anyone have any ideas/suggestions?? 2000 F350 4x4. 285-75-R16's.
Old Nov 28, 2007 | 06:30 PM
RckyMntnKng's Avatar
RckyMntnKng
Cupping is usually caused by incorrect inflation ive always been told.
Could that be part of the problem?
Old Nov 28, 2007 | 06:41 PM
Zephyr's Avatar
Zephyr
Might want to look into some new shocks if you havent already.
My tires were wearing choppy & I replaced my shocks & no more problems (new tires wearing smooth).
Old Nov 28, 2007 | 06:43 PM
JLDickmon's Avatar
JLDickmon
or they're just junk tires...
treads do squirm under load...
Old Nov 28, 2007 | 07:10 PM
lhud's Avatar
lhud
I had some tire wear problems and initially thought low tire pressure was the culprit. However, a front-end allignment mechanic suggested new shocks. New Belsteins seem to have corrected my wear problem.
LOL
Old Nov 28, 2007 | 07:22 PM
gunfrk's Avatar
gunfrk
Bad shocks crapped a set of Michellins for me. New shocks and a set of Centra-matic rings and all is very cool.
Old Nov 28, 2007 | 07:31 PM
JRStraight's Avatar
JRStraight
Thanks for all the input. I was leaning twords shocks. It has the Reflex shocks on it now (bought it with em). It sounds like Bilstiens are the favorite around here. I have Edlebrock IAS's on my 89 f250 and love em. So I was kind of leaning that way. But Bilstiens seem to be around $62each and the Edlebrocks are $75 each. I think I may give the Bilstiens a try.
Old Nov 28, 2007 | 08:08 PM
F350-6's Avatar
F350-6
How noisy are the Centra-matics? I assume they make some kind of noise at low speed.
Sorry to hijack.
Old Nov 28, 2007 | 08:09 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I know I need shocks. Still running the crappy stockers. I bet my tires need balancing too. They are cupped bad on the outside.
<table border="1" cellpadding="3" cellspacing="0" rules="groups" width="90%"><tbody><tr valign="top"> <td>
  • Improper Tire Wear
</td> <td>
  • Incorrect tire pressure (rapid center rib or inner and outer edge wear).
</td> <td>
  • ADJUST tire pressure.
</td></tr> <tr valign="top"> <td>
</td> <td>
  • Excessive front or rear toe (rapid inner or outer edge wear).
</td> <td>
  • ADJUST as necessary.
</td> <td>
  • Excessive negative or positive camber (rapid inner or outer edge wear).
</td> <td>
</td> <td>
  • Tires out of balance (tires cupped or dished).
</td> <td>
  • BALANCE tires.
</td></tr></tbody></table>
Old Nov 28, 2007 | 08:24 PM
Tenn01PSD350
Who has the best price on those Bilstiens? Christmas is coming.
Old Nov 28, 2007 | 08:28 PM
JRStraight's Avatar
JRStraight
Looks like eshocks.com $65each
http://www.eshocks.com/bil_veh.asp?M...=All&SubChar=Q
Old Nov 28, 2007 | 08:45 PM
PaysonPSD's Avatar
PaysonPSD
Auto Zone has them for $69.99. Not as cheap as eshocks or shockwarehouse but they have a life time warranty. If you have a problem you can just go back to AutoZone and not have to ship a bad shock back to supplier. I ordered them yesterday morning and they called me at noon today to come pick them up. They are on the truck already.
Old Nov 28, 2007 | 09:17 PM
Tenn01PSD350
That sounds great except that color is absolutely not working for me. If they don't come in a different color, I may have to paint them and that ought to void any warranty.
Old Nov 28, 2007 | 09:24 PM
PaysonPSD's Avatar
PaysonPSD
I agree. Shocking yellow shocks and baby blue boots. UGH! Break out the spray paint and black boots.
Old Nov 29, 2007 | 08:15 AM
whitesdford's Avatar
whitesdford
Mine are wearing on the inside really bad. Thought shocks may be the culprit, but it looks as it may be a camber issue. How does one fix that? Is that a huge deal to fix?
