Aerostar Ford Aerostar
Exhaust update!!!
Old 11-28-2007, 04:35 PM
DCRB's Avatar
DCRB
DCRB is offline
Exhaust update!!!
Ok so I now have my tail pipe, I went to autozone today and bought a Cherry Bomb high flow center to offset muffler (looks like it does a quick s loop inside the muffler) and now have this small tiny issue to solve:
My solution to the problem is this: have a muffler shop create a longer pipe that fits in between the flex pipe and the muffler, being that the tail pipe is already cut/bent/etc.
Ideas/comments/flames? lol
Ryan
Old 11-28-2007, 04:56 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
used as example pictures only, NOT purchasing source
http://www.partsamerica.com/ProductListSimple.aspx?Category=4066A
use adapters
go over exhaust pipe from flex and inside of muffler input
go over muffler output and inside the tailpipe
cheaper and easier than having someone weld and doesn't damage the aluminized coating
use only 3/8" inch U steel clamps.
the cheapy import 1/4" won't stay tight and break
grease the threads with some of that good wheel bearing grease
Old 11-28-2007, 05:14 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
You might ask your local muffler shop how much it would cost just to install that muffler. When they get that job, they will make the proper pipe section for the installation.
Old 11-28-2007, 11:45 PM
TallPaul's Avatar
TallPaul
TallPaul is offline
I just used the adapter pipe from the store. More fun to do myself.
Old 11-29-2007, 12:22 AM
DCRB's Avatar
DCRB
DCRB is offline
I'd do it myself, but i have to come up with an extra 4-6" of pipe between the flex pipe and the muffler....
Old 12-01-2007, 01:25 AM
DCRB's Avatar
DCRB
DCRB is offline
ok after actualy looking at what was undermy car vs. what i brought home, the person i got the catback from had the flex pipe replaced with a solid piece of pipe... which meants that I don't need any custom bent piping, which means that i can put it on myself!! i bought the 18" extension pipe i'll need tonight, will install tomorow and will post what it sounds like.... i'm soooooooooooooooo looking forward to actualy having a quite cabin again... my exhaust doesn't seem so loud till i ride in my paren'ts areo's that the exhaust is actualy going out the end of the tail pipe on the side of the car vs. underneith mine...
Gotanoldtruck
05-07-2014 03:43 PM
Midnite1987
03-26-2014 08:23 PM
DCRB
Aerostar
19
11-27-2007 06:11 PM
GqSnow
3.8 & 4.2L V6
11-20-2001 08:18 PM
Ryans460
Exhaust Systems
06-10-2001 11:12 PM
Quick Reply: Exhaust update!!!
