Sponsored by: Real Truck
Engine Cut-out
Old Nov 28, 2007 | 09:42 AM
F-350-diesel-man's Avatar
F-350-diesel-man
Unhappy Engine Cut-out
I have a 1993 F-350,7.3 DSL. When on either front or rear tanks, the engine will cut out at about 1/4 tank of fuel. This occurs on either tank. What could my problem be ,and the Fix for it? Also, when its parked on an incline after about 24 hrs, its hard to start, as though its out of fuel. If I switch to the other tank, it does start after awhile, sometimes it has to be pushed. It has a 5 speed standard trans...
Old Nov 28, 2007 | 10:22 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Try going down the threads page down to the 7.3 fourm. They might have more ideas for you,
Nick
Old Nov 28, 2007 | 10:24 AM
rugermack's Avatar
rugermack
Sounds like you need to do the in tank mods, maybe your pick-up in the tank is bent. Maybe weak fuel pump.
