need some traction
Old Nov 27, 2007 | 11:33 PM
65f100efi's Avatar
65f100efi
need some traction
I have a 65 F-100 that my dad and i putb a efi 5.0 in it and i am building a 347 stroker for and and i need to get some traction. not only does it suck when my 4.11 don't hook up but the real problem is my diff bobs around back there and i have bent a set of drive shafts already and and i need a trction bar of some type. one thing we converted to step side so we took out leafs. we are going to add all the leafs back and i think we are going to cut one of the long ones in half and drill and attack a snubber to them and make a traction bar out of them that will bolt into the u bolts on the bottom of the stack and i think this would help anybody else got any ideas. by the way we are on a budget.
Old Nov 27, 2007 | 11:38 PM
gustav129's Avatar
gustav129
I don't know about making a traction bar out of a leaf spring. That will flex quite a bit. Traction bars are tubular for a reason, they won't flex. I'd suggest getting a traction bar out of Summit. This is one of those things that it's not ok to "cut corners".
Old Nov 27, 2007 | 11:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
At one time, Traction Master offered traction bars for this era of Ford 9" rear axles installed in cars & trucks. The bars were tubular.
Old Dec 5, 2007 | 10:49 PM
65f100efi's Avatar
65f100efi
I raced a 73 corvette and got beat becuase i couldn't get a lick of traction in 1st and he kept gaining until i said screw it im going to second. i feathered the hell out of it and nothin. i have 3000 stall and anything below 3000 is normal acceleration and 3000 and above breaks the radial T/A's loose an i mean nothin, natta, zip for power to the ground. he got me the first race by a car and i got him the second by a half a car when i just shifted to second quick. so he thinks he is faster and wants to go agian. this time i talked him into some money. so i went out to the local tire and wheel shop got me some aluminum 15X10 wheels for $100 dollars and then after i cleaned up the wheels decided that i liked them i went and scounded up a matching set of 31X15 by 10.5W M/T ET Drag slicks. they fit the wheel well perfect and they grip perfect also they got more the half tread left and they ran me $100 for the pair also. now i got some tires and wheels that are way lighter, stickier, and straight up awsome. after a short burn out i can stall up to 3000 and lay in too it and HOOK HOOK HOOK. i love it and this time i will get 4 cars on him in first and another 4 in second instead of making up 4 cars in second. i guess we will put the money down before he sees my truck. chitty shevy's. and the great thing is if he gets slicks i will still eat him up becuase he already hooks.
Old Dec 6, 2007 | 07:14 AM
BobbyFord's Avatar
BobbyFord
Check into CalTracs.
Old Dec 6, 2007 | 09:33 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
65f-100efi
Welcome to (FTE)!
Sounds like you are having fun, at some point you will start thinking of going
(Pro-Street). When you start wanting even more traction take a look in my
signature, I have an article here and it can be done on a budget, its very safe
to! No cuttting the frame, no 4-link, no ladder bars. One more thing you are
talking about a 2WD,and not a 4WD right? I saw where you said a "set of
drive shafts," if you are talking 2WD then have a look at the article!
P.S. You are drag racing at a ( Drag strip ) Right? Be safe!
Wally Womack
Old Dec 6, 2007 | 07:06 PM
Hakk's Avatar
Hakk
+1.
A little searching will even get you plans for making them yourself if you're so inclined. They work great!
Old Dec 7, 2007 | 09:35 AM
Tiremine's Avatar
Tiremine
+2.
I made mine and they work great.
https://www.ford-trucks.com/user_gal...=99053&width=0
PowerstrokeRyan
Sep 30, 2011 06:18 PM
t_hess66
Jun 3, 2011 03:33 PM
klemklubfoot
Aug 19, 2008 01:50 AM
78bigbronco
Jun 15, 2005 09:01 PM
KJKozak2
Offroad & 4x4
27
Apr 22, 2005 08:22 PM
