original order form
Old Nov 27, 2007 | 07:25 PM
clgreer's Avatar
clgreer
original order form
i was putting new upolstery on my seat today and found the original ford order form folded up in the old stuff. thought that was pretty cool. 34 years old and still there...
Old Nov 28, 2007 | 06:59 PM
rusty7983's Avatar
rusty7983
i wish i could find mine.
Old Nov 28, 2007 | 07:36 PM
daltonw's Avatar
daltonw
I found the one from my dads 76 taped on the back side of the dash
Old Nov 28, 2007 | 08:40 PM
Mil1ion's Avatar
Mil1ion
That's actually called a Build sheet.
It follows the truck thru the assembly plant to make sure all the correct things go on it.
also look for the original IBM computer card.
Old Nov 29, 2007 | 12:48 PM
clgreer's Avatar
clgreer
either way filled with lots of good info, if your trying to restore to stock as it has all the casting numbers on it.
Old Nov 29, 2007 | 02:25 PM
monsterbaby's Avatar
monsterbaby
stuffed into the seat springs is the most common, although not only place you will find them and you will almost always find them. But check the VIN against yours because sometimes the seats have been swapped out at one time or another. actually found a car that must have been restored a couple times that had 3 different build sheets in it for 3 different cars when we went looking (went looking because the motor that was in it didn't fit what we thought should be and turned out it wasn't right)
Great thing is you will look at some of the late 60s early 70s cars those build sheets are sometimes the only way to prove something was built a certian way. Me and a friend actually bought a mercury station wagon one time, he wanted the rear end and I wanted the 429 out of it. upon tearing into it found a 4 bolt main block and a few other oddities turned out o be a cj motor and the build sheet confirmed it was original. Now wish we hadn't parted that one out since a factory original 429 CJ station wagon would definatly qualify as rare and probably be worth a small fortune
Old Nov 29, 2007 | 04:49 PM
Mil1ion's Avatar
Mil1ion
Casting numbers ?
I think you mean Build codes ?
That's all a build sheet has on it.
Old Nov 29, 2007 | 06:31 PM
Dustin1690's Avatar
Dustin1690
That is cool when you find things like that.....
Old Nov 29, 2007 | 07:34 PM
EdwrdEdmnds's Avatar
EdwrdEdmnds
i found mine in the seat springs all tattered. i saved all the pieces put them in a sandwich baggy for now. 1978 f-350 140 inch wheel base custom trim 5.8 L (M)
c-6 transmission dana 70 rear 4:10 limited slip painted candy apple red...
69cj
6.7L Power Stroke Diesel
Mar 12, 2014 08:51 AM
abe
18
Jan 14, 2013 03:25 PM
Old F1
17
Aug 19, 2009 07:28 AM
86stepsideF150
Exhaust Systems
Sep 16, 2007 08:14 PM
