IAC - idle controll solenoid, located on throutle body, but I'm not sure, it is stuck open. First check all vac. lines. You will see vac. lines diagram on sticker under the hood.
Perfect French, but I understand one word only....
BTW, Qautchat, how do ypu do there in France... Watching TV this morning I saw you have new problems with Afrofrenches.... What your president will do now? Move all away from France?
My friend told me, he had similar problem with stuck C/C. Check for correct idle troutle position, you may smile, but I have 0-6V voltmeter in cabine and 8 position switch and I can check TP sensor position, ECT, IAC and other sensors on run.... :-))
EXCELLENT post with photos!! Perfect, that helps more than a 10,000 word written essay description of the problem (and the fix) concerning the Ford IAC.
Nice work, 96, you guys are true Aerostar GURUS / EXPERTS / MINI-VAN MESSIAHS!
Ed '87 Aerostar XLT 3.0V6, solid, rust free NoCal 'STAR!
