Front hub bearing service, any pointers?
http://guzzle.rbmicro.com/nblube.html
Does anyone have any helpful hints or tips for me while I'm getting into it? One thing I will do is the vacuum check(see next to last step) of the ESOF hubs before I take them apart. That way if I have a leak I'll get the new inner hub seals before starting the job. I also see that there is a sealed bearing below the needle bearing. I take it there is no way to access or check this bearing out, is there?
I plan on using Super Lube synthetic grease for the bearings and caliper slide pins. It has a temperature range of -45 to +450 and lists both wheel bearings and calipers under automotive uses. I already have the Multi-purpose Heavy Duty grease but was wondering if it would be better to use the High Temp/Extreme Pressure grease instead. It's not like these bearings get repacked often. Any input on using this grease or the HT/EP grease is appreciated as always.
http://www.super-lube.com/pdf/Catalog.pdf
"Behind the race sits the large knuckle seal that would need to be replaced if your ESOF hubs have a vacuum leak as this is the most common point of failure that will cause the hubs to not hold vacuum. Failure of this seal will also allow the vacuum pump to draw in moisture and dirt, wihich will accelerate needle bearing failure."
I have the new yellow O rings already but the dealer I went to didn't have the locking hub kit so I'll try another dealer tomorrow. OEM caliper slide pins were $21 per corner, I'll get a price from Advance tomorrow for AM pins. I plan on cleaning mine up as best I can for now and replacing them when I do the brakes. I'm collecting data on that now and it looks like the concensus opinion is that the premium pads and cryo rotors are worth the money. At least the brakes should be fairly easy to do next time around....
I tried to find a seam like Rusty talked about for that sealed bearing, I have needle tips for grease guns, but it was not obvious in the fading light. I'll look again in the morning. Has anyone out there injected grease into the sealed bearing with a needle and could give me some tips on it?
https://www.ford-trucks.com/forums/6...ml#post5405275
Like many other guys my driver's side went out at about 70k miles and I sort of knew the cause was water in the bearings. Therefore, I decided to go ahead and replace the other side and have both sides new. My truck is an '02 CC, 4x4, Lariat and the front bearings are the non-serviceable units.
However, I discovered that you can in fact lube these units by removing the ABS sensor which exposes the motion gear inside and it is located between the inside and outside tapered bearings. This provides grease access to both of these bearings.
I simply shoot a few shots of grease in this hole with an adapter on the grease gun, then rotate the bearing several times to distribute the grease; do this several times until you feel a good resistance to the rotation. Then install everything back to original condition. This may not be a 100% cure, but it is better than doing nothing to the bearings.
I tore the bad bearing apart and discovered that this unit has the inside/outside races machined into the housing. Therefore, you cannot replace the races even if you replaced the tapered bearings. I am guessing Ford had these out-sourced.
