65 complete wiring harness
Old Nov 25, 2007 | 08:59 PM
bliss1's Avatar
bliss1
does anyone know if there is a supplier of complete harness for65 f100. sense the truck has had several owner doing there own thing i thought i would just replace the whole thing.
Old Nov 25, 2007 | 09:05 PM
matt2491's Avatar
matt2491
A universal Painless kit should do it. They're somewhat expensive though.
Old Nov 25, 2007 | 09:15 PM
bliss1's Avatar
bliss1
i know ive look and it will set me back around $450
Old Nov 25, 2007 | 09:52 PM
gustav129's Avatar
gustav129
A universal for $450?! Wow, they must have gone up quite a bit since last year.
Old Nov 25, 2007 | 10:03 PM
iiizman's Avatar
iiizman
Haywire, Its a brand name/
Old Nov 25, 2007 | 10:04 PM
gustav129's Avatar
gustav129
http://store.summitracing.com/partde...5&autoview=sku
Summit Racing Part #PRF-10104
Painless Performance Universal Truck Harness
$375.95
Old Nov 25, 2007 | 10:40 PM
bliss1's Avatar
bliss1
ron francis has one For $359, anyone use them.
Old Nov 25, 2007 | 11:26 PM
daveengelson's Avatar
daveengelson
Found company who makes reproduction harnesses for 64-67 Ford F100 trucks. Unfortunately, have not been able to find anyone who makes repo. of the 'dash harness'. Replaced wiring harness's for my 65 and very pleased w/ the quality and duplication of the original. Same connectors and wire codes, matter of unpluging the old and plug in the new.
dave
Old Nov 26, 2007 | 12:02 AM
frty7ford's Avatar
frty7ford
I put a Ron Francis one on a 81 I had. easy to install Hardest part was figuring out where I wanted to put the fuse block. It was larger than the original.
Old Nov 26, 2007 | 12:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
dave
As original, there was no separate dash harness. It was included in the main loom. The only separate wiring harnesses were the taillight loom, engine gauge feed loom, the alternator loom and the headlamp loom.
The looms used for 1965/68 Mustangs (they have been reproduced) can be substituted for the truck looms, since the underhood parts are the same. Same alternator & regulator, starter relay, coil, oil/water temp senders, horns, etc. The resistor wire from coil to ignition switch is the same.
The headlamp looms used on 65/73 Mustangs uses the same plugs as 1961/72 pickups. More splicing: The Mustang taillamp loom has the same plugs as the trucks do. Mustang looms must be spliced into the trucks wiring harness.
Splicing wires behind the dash: Mustangs used the same gauge hookups, same ignition switch (1965/67), same headlight switch plug, etc. The Mustang dash loom has also been reproduced.
Old Nov 26, 2007 | 12:10 PM
bliss1's Avatar
bliss1
im thinking ron francis seens im going to put in a 95 engine, should allow me more flexability.
Old Nov 26, 2007 | 09:32 PM
Kongslibakken's Avatar
Kongslibakken
Hey Dave by chance do you remeber the name of that Company.
Old Nov 27, 2007 | 12:33 AM
daveengelson
Purchased thru Mr. Mustang, Inc. this was couple years ago, not sure if they are still around. I purchased the Alernator, Headlamp, taillamp harnesses. The headlamp, and tail lamp ran about $100 each, and the alternator $50. They offer additional harnesses, fuel, dome. I was very satisfied with the quality so I purchased an extra set for my other 65, did not want to take the chance supplier would go to the way-side like many others. If interested I can take pic's of the extra harnesses and try posting in my gallery tomorrow. Don't think they have a web site anymore, could not purchase online had to contact them by telephone. Again, it's for 64-67 Ford truck F100's, Order line: 1-800-543-9195, Information line: 937-275-7439, and Fax: 937-275-4346. If able to contact, they would probably fax price sheet, and if concerned about the quality may want to purchase 1 and check it out. Opps, rambling again, honestly not affiliated with them, and don't get a commission.
dave
