leaking head gasket i think
Old Nov 25, 2007 | 07:54 PM
shuttlevalve's Avatar
shuttlevalve
I finally got the 347 tuned and running pretty good in my 93 ford F150. Like clockwork it looks like the right head is leaking anti-freeze after 6000 miles. It pretty much sucks i just had the intake off to change a bad lifter. I even went the extra mile and had the head resurfaced, used ARP head studs, and felpro gaksets. I have never had a head gasket ever leak that i have changed up to this point. I guess i'll retorque the bolts and toss a couple of those sealing tablets and hope for the best. Its getting darn cold to be pulling heads.
Old Nov 25, 2007 | 09:12 PM
Putt's Avatar
Putt
I would be more suspicious of the intake than the head. They are known to be hard to seal, try to torque the intake again.
Old Nov 26, 2007 | 04:17 AM
HemiEater's Avatar
HemiEater
if the lower holes go into water you should always use a thread sealer on them.....with the cooling system full, pull a lower stud and see if any water comes out. if you do get water drain the system and seal one stud at a time. I use Felpro thread sealer...never a problem...
Old Nov 26, 2007 | 07:04 AM
shuttlevalve
the lower bolts do go into the water jacket. i used sealer on all the bolts. i looked over the intake in the front and cant see anything, the only thing i can see is at the forward corner of the block.
Old Nov 26, 2007 | 11:57 AM
shuttlevalve
After further review its looking like a intake or the thermostat housing. I knew when i installed the intake it was looking a bit pitted and corroded, so i cleaned it up and added silicone all the way around all the water ports. i guess i may have to beak down and dig up a low mile used one or get this one welded and milled back down
Old Nov 27, 2007 | 11:21 AM
Mr. M's Avatar
Mr. M
Good Luck shuttle.
Old Nov 27, 2007 | 10:20 PM
baddad457's Avatar
baddad457
If you're running a chrome T-Stat housing, that's always a leak source too. The gasket nor O ring type seem to be able to contain the coolant.
Old Nov 28, 2007 | 10:08 PM
Putt's Avatar
Putt
shuttle, I used JB Weld to repair a leaking t-stat housing on an old Edelbrock Torker once, it worked fine for the year I had it. I also built up the carb base with it, you can file it by hand.
Not exactly the best way, but if it works?? A lot cheaper!!!!
