Front Main Seal leak?
Old Nov 25, 2007 | 06:06 PM
SpectreZ91's Avatar
SpectreZ91
Truck is a 2001 7.3l diesel of course.
Well I found oil all over the front of the truck... on the front axle. tracbar, ect.. I cleaned it all and ran the motor and it appears to be leaking from behind the harmonic balancer (crank pulley). and dripping down to the lower radiator hose.
Is there any other place that oil could come down above the pulley and drain around it?
How hard is the main seals on these to change? Any write ups?
I appreciate all opinions... thanx
Old Nov 25, 2007 | 09:25 PM
jtharvey's Avatar
jtharvey
There is a seal behing (may be in it) the stock balancer that could have gone bad. You should be able to get them from Intl for less than $20 IIRC. You will have to pull the balancer to do it though, which will require a puller. FWIW, if I were in there I'd put a new oil pump in. Once the balancer is off, it's only 4 bolts holding it in there. ITP diesel sells a melling pump, I think they're about $80.
Old Nov 26, 2007 | 04:16 AM
ron's power stroke's Avatar
ron's power stroke
might want to check the oring on the CPS..mine leaks and looks like the front seal..put in a new CPS sensor i had and the leak stoped..
Old Nov 26, 2007 | 08:24 AM
Kwikkordead's Avatar
Kwikkordead
Ron you beat me to it. I had exactly the same thing and a nice shiny new grey CPS was the cure.
Less than $30.00.
Old Nov 26, 2007 | 10:44 AM
SpectreZ91's Avatar
SpectreZ91
Ah.. so a CPS will make it look like a bad front main? I know our CPS needs to be replaced.. It will intermitently give us issues. I'll try that first.. I can't say I'm praying for a cheap fix cause the cps and main seal are pretty much the same price, but the cps would be easier to change.
Old Nov 26, 2007 | 12:30 PM
ron's power stroke
go to a ford dealer and get the new gray CPS..its only 25 bucks now..give or take..one of our sponsors has then for 15..cant remember who...
Old Nov 26, 2007 | 01:35 PM
SpectreZ91's Avatar
SpectreZ91
Nice.. 25 bux is good..
I looked at our local parts chain website and they still list it for 149.. I'll go to the dealer for this one.
Do the CPS leak bad enough to have enough oil drip down and then get sprayed everywhere by the fan while it's running?
Truck only has 120k on it.. I'd hate to have to worry about main seals going out.
Old Nov 26, 2007 | 01:38 PM
ron's power stroke
yes it can...mine got the whole bottom of my pan wet so bad when she is parked it would drip from the back of the pan..
Old Nov 26, 2007 | 01:43 PM
SpectreZ91's Avatar
SpectreZ91
The more I think about it.. I remember seeing oil up there by the CPS (but had forgotten that's where it was)
Saw oil all on the timing mark as well.. I didn't really notice until I saw the whole diff and track bar were covered in oil. spots like it had been blown all over the place by the fan..
Wish I was home now to take a better look at it..
Old Nov 27, 2007 | 04:53 PM
SpectreZ91's Avatar
SpectreZ91
Well looked again last night.. Saw oil from behind the crankshaft pulley but couldn't see if it came from up top
I do see oil on the electrical wires that plug into the CPS and on the timing mark indicator.. I'm wondering if it is the cps for sure and dripping down..
Unfortunetly I have to wait to sell a few things.. money got tight and the rear pads are shot.. ended up toasting one of the rotors in the rear.
Old Nov 27, 2007 | 05:02 PM
ron's power stroke
a new CPS is only $25 at the dealer now..or get just the oring..write these##"s down and see if napa, IH or some one to cross them...
<TABLE id=DataGrid1 style="BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=3 rules=all border=1><TBODY><TR style="FONT-SIZE: smaller; FONT-FAMILY: Verdana, Arial, Helvetica, sans-serif; BACKGROUND-COLOR: #e5e5e5"><TD>CPS</TD><TD>Buna-N</TD><TD>3/32"</TD><TD>13/16"</TD><TD>1"</TD><TD>McMaster-Carr</TD><TD>9555K26</TD><TD>25/$4.22 </TD><TD>117</TD><TD> </TD></TR><TR style="FONT-SIZE: smaller; FONT-FAMILY: Verdana, Arial, Helvetica, sans-serif; BACKGROUND-COLOR: #f2f2f2"><TD>CPS</TD><TD>Viton</TD><TD>3/32"</TD><TD>13/16"</TD><TD>1"</TD><TD>McMaster-Carr</TD><TD>1201T54</TD><TD>25/$9.56</TD><TD>117</TD><TD> </TD></TR><TR style="FONT-SIZE: smaller; FONT-FAMILY: Verdana, Arial, Helvetica, sans-serif; BACKGROUND-COLOR: #e5e5e5"><TD>CPS</TD><TD>Viton</TD><TD>3/32"</TD><TD>13/16"</TD><TD>1"</TD><TD>Grainger</TD><TD>1KFL5</TD><TD>50/$9.17</TD><TD>117</TD></TR></TBODY></TABLE>
Old Nov 28, 2007 | 04:14 PM
SpectreZ91's Avatar
SpectreZ91
I need a new CPS anyways.. It's been giving us issues already.. Just not enough to replace it... But I'm going to anyways..
Old Nov 28, 2007 | 05:53 PM
SpringerPop's Avatar
SpringerPop
Has anyone considered that this leak might be diesel fuel?
The drain valve's "extension" tube ends right about where he is describing a leak.
Pop
