Cold weather brings problems back
Old Nov 25, 2007 | 05:01 PM
vatreefarmer's Avatar
vatreefarmer
Last year I had problems in my '06 PSD in cold weather. When cold (below 25 degrees) it would start then die right away, it sometimes took 2-3 attempts before engine would run at startup. So I changed oil to synthetic and had inductive heat flash on the same day. Problem was resolved.........Until..............Saturday AM temp was 15 degrees and the problems returned, I had changed oil using Motorcraft 15-40. Should I simply switch back to syntyhetic for cold weather or do I have hidden problems?
Old Nov 25, 2007 | 05:06 PM
doubledee715's Avatar
doubledee715
hidden? you have symptoms. it's not hidden. may be injector stiction. I also believe I am experiencing some.
Old Nov 25, 2007 | 05:08 PM
mhoefer's Avatar
mhoefer
15w40 oil is way to thick for these temps, you should use 10w30 dino or 5w40 synthetic. Did you change the oil this fall to 15w40? Dealer should be changing you to 10w30 or atleast asking.
Old Nov 25, 2007 | 05:20 PM
vatreefarmer
My plan was to use dino 15-40 in the summer and syn. 5-40 in winter. I usually have it done at my mechanics. However, since I wanted dealer to change fuel filters (throw some business his way, let him keep records of service done in case of warranty issues) I let them change the oil too. Service writer (not diesel tech) said since Ford says 15-40 in our area that I should use the 15-40. I guess I'll have the oil changed AGAIN this week to synthetic.
Old Nov 25, 2007 | 06:25 PM
doubledee715
I guess some trucks may react differently to oils. I've started my truck up using 15w-40 Delo in 14 degrees no problems. Even before my inductive heat strategy installation.
Old Nov 25, 2007 | 06:38 PM
thedaddycat's Avatar
thedaddycat
You don't need to have the dealer service your truck in order to log it. I have my truck registered here and enter whatever I do into the log. I still have some things to add(like all the rotate/balance/alignment checks) but all the dealer servine is in there too....
http://myford.fordvehicles.com
Old Nov 26, 2007 | 11:07 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
This may be a dumb question but are you using any anti-gel additive? Could it be fuel- related?
Old Nov 26, 2007 | 06:12 PM
a-rod's Avatar
a-rod
Im wondering the same, possibly some fuel gelling up in the lines or something..... Ive never heard of injectors causing the truck to start and then die right away when cold. Never trust your fuel, always run an additive!
Old Nov 28, 2007 | 02:49 PM
deercreek1's Avatar
deercreek1
I'm experencing the same problems here in Minnesota. I have also noticed that when starting out cold the truck will not shift into 2nd gear until almost 4,000 rpm's.
Old Dec 2, 2007 | 08:10 PM
vatreefarmer
**UPDATE* the change back to synthetic 5w-40 oil once again resolved the problem. Turned out to be a rather expensive waste of dealers oil when I only put 500 miles on it.
Old Dec 3, 2007 | 01:28 PM
Canadian 6.0's Avatar
Canadian 6.0
thedaddycat> do you know if they have such a sight as you have linked to for canadian trucks?
quakerj
19
Nov 17, 2013 11:17 AM
Kert0307
Jan 20, 2011 01:49 PM
Paul Moody
28
Jan 4, 2008 12:11 PM
sean brady
Jan 30, 2007 09:39 AM
