O.K. guys, need some help here.
I have a 1976 300 I6 (in my 1972 F250 CrewCab, divorced transfer case, 4 speed manual)
Want to put a C4 from a '72 cougar (351W) have the whole car. What do I need to make this swap?
Will this tranny bolt right up?
Output shaft the same?
Driveline length?
Use the flexplate from the 351W?
Balancing issue?
What starter do I use?
radiator with tranny lines form the Cougar?
Shifter?
