engine noise
Old Jan 18, 2002 | 09:19 PM
ksmith's Avatar
ksmith
engine noise
I have an 81 f150 with 300 six cyl,I like the motor but it's just so noisy i'm not sure if it's a rod or something else. With motor running and in gear it sounds o.k. but when you're driving you can hear that annoying noise it's a combo of the dieseling sound and a light knock. As far as the knocking I was thinking the flywheel might be cracked I had a few of those before they made a similar sound.Any suggestions would be helpful.
Old Jan 27, 2002 | 09:41 PM
truckfreak69's Avatar
truckfreak69
engine noise
what RPM range do u cruise in? the dieseling could be from the RPM's being too low, because under 14-1500 RPM mine makes the same noise, so i try and cruise at 17-2000? Prolly not it but figured i'd reply cus someday i hope to be a help to someone eh? hehehe
Old Jan 28, 2002 | 02:03 PM
whittey's Avatar
whittey
engine noise
Hrm, I never heard of that problem with the carbie versions, only the EFI ones. My '81 didn't do it but my '89 does. I can't but help thinking that its a bad thing (assuming as did the poster above me that its low-rpm) so I try to keep my revs up as well.
-=Whittey=-
Old Jan 28, 2002 | 03:33 PM
rustydog's Avatar
rustydog
engine noise
