Stuff in the oil
Old Nov 25, 2007 | 07:19 AM
abigjeep's Avatar
abigjeep
Stuff in the oil
98 EB exy with 5.4 and 160k miles.
I have had the problem with bad vacuum lines (po 406 etc.) I repaired all the vac lines and cleaned the TB etc. I checked the oil and it's full of creamy "stuff" that makes me think there was moisture sucked in there when the pvc plumbing was leaky. Any suggestions on how to clean this up? Prior to this problem the oil has always been nice and clean. Engine runs well.
Thanks!
Old Nov 25, 2007 | 10:07 AM
galaxie641's Avatar
galaxie641
Sounds like condensation from a short run time.
Old Nov 25, 2007 | 12:38 PM
abigjeep's Avatar
abigjeep
That happens from time to time but this week it's gone 175 miles over two days. Any ideas on how to prevent such things?
Old Nov 27, 2007 | 11:36 AM
Modified 99's Avatar
Modified 99
If you have a carmel colored substance on your oil fill cap its MOISTURE. IF after the 175 miles you mentioned above you should change the oil and filter. Water in the oil DOES NOT make a good lubricant
Old Nov 27, 2007 | 11:58 AM
abigjeep's Avatar
abigjeep
That's step 1. I was going to add some seafoam for a couple days prior to help clean things up. So what are my preventative measures?
Fordownsall
19
May 9, 2011 01:32 PM
RobertJohn
Mar 12, 2010 08:46 PM
Tomget
1983 - 2012 Ranger & B-Series
May 10, 2009 10:05 PM
rpss4844
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 27, 2007 11:33 PM
