carb/float problems '72 300 I6
Old Jan 28, 2002 | 04:57 PM
Supercab's Avatar
Supercab
I've got what I think is two problems with the stock carter YF carb on my '72 300 I6:First off I rebuilt it, and it seems to run ok, but when I shut it off & it sits a little while I can smell gas pretty strong(outside of carb is dry)and when I go to re start it it seems flooded sometimes I have to floor it to get it to start, the other simptom is that if I idle in gear for more than 2 minutes it will start to run rough, and upon accelleration it bucks some until I get up to speed.
The rebuild kit I used had a "new" type of needle & seat, which was seald, plus I didn't adjust the float level because I figured it was OK, and I really couldn't understand how they explained the adjustment. Thanks!!!!!!! Rick
Old Jan 29, 2002 | 07:11 AM
rtbstrd's Avatar
rtbstrd
You probably notices a drop in mileage too, eh? Assuming the float needle is in right, sounds like your float level could be too high - I just rebuilt a YF and adjusted the float level exactly according to the directions, noticing that I had to bend it up considerably from where it was, and I got boil over and flooding. Took care of the problem by adjusting the float down to about where it was before the rebuild.
Old Jan 29, 2002 | 08:38 PM
fordman75's Avatar
fordman75
PatientZero
Aug 10, 2012 10:46 AM
jeffreysw
21
Aug 15, 2011 08:56 PM
f100gregus
Aug 13, 2006 11:57 AM
Scott Fraser
Nov 24, 2004 10:25 PM
dcs
Apr 15, 2002 10:52 PM
