Anyone added the backup camera yet?
You have a rear view mirror now! (Looks juts like the one that comes on the trucks.....
However if you install a new radio with a DVD screen option...Slides in & out of the radio when you play video ..Then you can use that screen..The camera by itself is 99.00 with the rear view mirror kit 169.00
These numbers don't contain the prefixes or suffixes (ie, xxxx-19G940A-xx for the camera) but any competent Ford Parts employee should be able to look these up for you.
14B562 Rear Wiring Harness for Camera
14334 Cab/Roof Wiring Harness
17700 Electrochromatic Mirror w/Video
19G940A Rear Video Camera
99431B82 Tailgate Latch Handle for Rear Video Camera
It will be necessary to purchase both the 14B562 and 14334 wiring harnesses, as pigtail connectors are not available for either of these components.
I will first say that this should NOT be attempted without at least moderate knowledge in basic wiring.
I've uploaded the wiring diagrams to our website, please click at the bottom of the post. You will need to download the Adobe SVG Viewer to see the files (and you'll have to be using Internet Explorer too, they won't open on Mozilla Firefox). Also, opening these files may trigger blocked content and some errors; just OK all the errors and authorize the blocked content warning.
It really isn't feasible to try to use ALL factory wiring, since there are about 12 different harnesses that would have to be changed depending on build date and configuration of the truck.
The Video + and Video - signals from the camera at the tailgate need to be connected to the mirror screen. If you already have the electrochromatic mirror, the to video connections and the corresponding ground (you can ground it anywhere) will be all that's needed to connect to the mirror itself. If you only have the basic mirror, you will need to connect a switched hot power source to the mirror along with the compass + and - connections out of the back of the instrument cluster----
The compass wires are- Blue w/Grey Stripe for the positive
Grey w/Blue Stripe for the negative
Simply tap into these wires at the back of the instrument cluster, route, and connect to the mirror.
As for the camera itself, you will need to route the Video + and Video - wires (white/green and brown/violet) from the camera at the tailgate to the mirror inside. The camera will also need a switched hot power source (you can use the same one as used for the mirror if preferred- just make sure it is fused high enough for both) and a ground out of pin 6 of the connector. The other black wire at the camera connector is the video shield (do NOT get the ground and shield wire crossed up- reference the connector pinout I linked to). This wire needs to run the full length of the video + and - wires, but will connect to nothing at the end, so just tape it up before the mirror.
The last connection will be the reverse lamp relay connection to the mirror; which will activate the screen itself when the truck is put into reverse. The easiest place to tap into this is from the Green/Brown wire coming from the back of the Battery Junction Box under the dash, behind the reverse lamp relay (see associated link for the diagram).
It would be far too detailed to try to explain the proper routing of the wires- common sense will be needed here. They simply have to reach from the mirror, through the interior, to the frame rail and to the rear of the truck. The wiring MUST be routed through the holes in the hinge pins on the tailgates to avoid damage to the wiring as the tailgate opens and closes.
Here are the links to the wiring diagrams:
Battery Junction Box Diagram
Reverse Camera Reverse Lamp Relay
Reverse Camera Wiring Diagram
Rear Video Camera Connector Plug Pinout
Now sombody needs to find prices for all those part numbers. Unfortuently as you know Ford doesn't help out their customers when they price their parts. So this looks quite expencive.
I have both the alarm and the camera, factory. My wife has a LEXUS and I like the FORD system better. Here is why. You get a field view that shows a green area, an amber area, and a red area. I can only tell you what the salesmen told me, and I have not verified, BUT when you back up it views the distance from the obstruction and you actually see the distance from say 9 feet, green; 6 feet amber; and, 3 feet and less red. NEAT
Mine is long bed, 22'-4" long and 172" wheel base. If you are going to order a truck, this is from heaven.
