Fuel Injector Pulse Width
Old Nov 24, 2007 | 08:12 PM
mendeldl's Avatar
mendeldl
I just bought a 94 Explorer XLT 4.0L and the only problem I can find is a continuous code being thrown that says the Fuel Injector Pulse width is either hi or low. I'm wondering if the code (186 I believe) is an indication of the input to the injectors or output. In otherwords is the most likely suspect the injectors themselves or what ever tells them to fire. The engine seems to run reasonable well regardless of the condition.
Regards,
David
Old Nov 24, 2007 | 09:26 PM
99f350sd's Avatar
99f350sd
I'm suprised you are not getting another code with it.
Clean your MAF sensor...
Old Nov 24, 2007 | 11:16 PM
mrshorty's Avatar
mrshorty
CM 186 doesn't point to a problem in the fuel injectors. It points to a problem in the sensors used to determine fuel mixture: principally MAF and O2 sensors.
Does it pass the KOER test? Have you cleared CM to see if this code keeps coming back or not?
Old Nov 27, 2007 | 10:13 PM
mendeldl's Avatar
mendeldl
Yes, it passes the KOEO and KOER. I cleared the codes from storage and it always comes back about 5 minutes into a drive (generally under heavy load conditions). Tested and cleared about 3 times last weekend. That's good to know that it might clear up with a MAF cleaning or O2 sensor change.
Regards,
David
Old Nov 27, 2007 | 10:17 PM
99f350sd's Avatar
99f350sd
bad 02 sensor would throw a code? no...if its over 80k miles replace it. clean the maf.
Dick
dirkdriller
Jun 5, 2017 05:04 PM
jon705
36
Mar 12, 2013 11:05 AM
Aki_A
Jul 29, 2010 11:50 PM
utjer
Mar 24, 2010 10:41 PM
mantta
Dec 7, 2002 01:50 AM
