I see quite a few sheep herder trailers being towed in tandem but the second trailer is on a fifth wheel dolly. Legal or not, I don't know but they do it.
That is about what I was going to say, I dont know if it is legal or not, but I see plenty of people pulling thier boats behind thier bumper pull tt.
Most of my trips are less than 100 miles and running a little slower won't hurt my feelings to bad but it would be nice to get both my rigs there without having to drive the toy. It's not very well road mannered. Plus the road miles on those off road tires just makes me cringe.
I pull 2 sometimes A boat & 2 jet skis behind it. it pulls reall good you just have to remember them in those tight construction zones because when you move the wheel a little bit its exaggerated by the 2nd trailer & moves quite abit. ive backed into the water to drop the jetskis fully hooked up but it can be tedius.im getting ready to put a hitch on my 5th wheel camper next. he`s right about state laws they vary some allow it & some dont & some require a cdl with doubles endoresment.
mine are bumper pulls havent been pulled over yet but that dont mean it`s legal. my boat weighs about 5800 lb & the jet ski`s ill guess at 2100 surge breaks on both. you wouldnt want electric brakes on the 2nd & surge on the 1st because that would rob braking power realasing the surge brakes on #1. plus ive only pulled through ohio,kentucky & tennessee. I hear their real strict in fla.
Here in Idaho they tend to be pretty easy going if you're not presenting an obvious and glaring safety hazard. I'm just wondering how hard it will be to get them behaving like they should.
Whats wrong with a gooseneck?
I've never pulled either but I like the fact that gooseneck hitches don't take up the bed.
The only issue I have found with a gooseneck is with tall 5ers. The stability is not there compared to a 5th wheel hitch, but if I had smaller trailer I wouldnt hesitate to use a gooseneck.
I would like to try a trailer with a jap jeep (Suzuki Samurai 2200 lbs) on it behind a 18 ft camp trailer (3800 lbs). I wonder if I should equalize the first or second trailer? This might be some trial and error.
Just dont know how that would act, that back trailer is almost as heavy as the first & if it started whipping on you it would probably pull you off the road.my little jet skis have a low center of gravity & behave real well,but a car on a trailer is a whole other story.
Anybody pull two bumper pulls? I want to give it a try but I don't want to go to the trouble of hitches, wiring and such if it's not gonna work.
I do it some...Usually with 2 20' trailers. I just do it on the farm hauling hay and tobacco. I am on the road some, but usually it's under 10 miles and I have to keep it under 30.
As far as the gooseneck, I think Grey is refering to adapters, rather than the hitch itself. Gooseneck trailers are just fine, as are fifthwheels, but converting one to the other poses problems with stability and strength; each hitch has a different stress frame and different design goals.
Here is what I'm thinking, legal or not. If what ever you are towing does not have enough tongue weight (even single trailer) it will cause you to whip on braking or deceleration. If the second trailer has to much tongue weight it will counter the first trailers tongue weight causing this problem. If each trailer is loaded just right as to have the correct amount of tongue weight on each of them the out of control whipping should be under control. Understanding that all turns and corrections are magnified on the second trailer, using a little common sense and taking it slower say 55 mph max. (if I'm lucky) It should work ok.
I think using a load equalizer on the second trailer may help to adjust both trailers tongue weights and help with sway control on the second trailer.
I'm going to start on the hitches and lighting and such this winter. I hope to try this in the spring. I'll get back on here and let you all know how I come out. Hopefully you won't be hearing it on the evening news LOL!
Another option is to flat tow the Jap Jeep, that would eliminate the tongue weight issues but would still be putting the road miles on the off road tires.
Any input you all might have for me to consider will be greatly appreciated.
