6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tracton Control
Old Dec 19, 2007 | 04:44 AM
jam105's Avatar
jam105
Not according to this.
http://media.ford.com/products/press...422&make_id=92
Old Dec 19, 2007 | 11:01 AM
Sayonara's Avatar
Sayonara
im so confused..... so if we dont have the "optional" TC should we have a shut-off smewhere for the engine torque TC?
Old Dec 19, 2007 | 05:00 PM
jam105's Avatar
jam105
You will have the switch (push button) only if you have the TC...No switch for the engine torque.
The switch is right beside the 4X4 electric switch....
Old Dec 19, 2007 | 08:00 PM
Sayonara's Avatar
Sayonara
Whew! thats what i thought - Thanks! 1 less button to worry about...
Old Dec 19, 2007 | 08:35 PM
bnmccoy's Avatar
bnmccoy
Jam, I have no argument that Ford indicated that all would have it in their early press releases, etc.
My point is that I do not believe there are two different types available as posted by someone else: 1) one, being standard that is engine torque management; and 2) a second being optional that operates as conventional traction control by using the ABS to modulate brakes to the slipping wheel.
I hope you are successful getting Ford to add it to your truck.
Bob
Old Dec 19, 2007 | 08:49 PM
jam105's Avatar
jam105
Bob
According to Ford they are two seperate systems. I know I did not have the switch. I argued the point and they bit the bullet and installed the other type in my truck. I tested it and it works great...I did loose 1 mpg with it though.....
ITAngel
1997 - 2003 F150
Jun 26, 2014 09:30 AM
Monty Simmons
Feb 9, 2014 08:15 PM
senix
6.7L Power Stroke Diesel
Mar 4, 2010 08:35 AM
daved366
36
Jul 4, 2009 06:34 AM
tunnel vision
16
Apr 10, 2008 01:23 PM
