Sponsored by: Auxito
plug boots
Old Nov 24, 2007 | 02:29 PM
fordboy_52's Avatar
fordboy_52
plug boots
so the 5.4 plug boots dont clamp onto the plugs? i tuned my truck up and put die-electric grease in each boot. driving home my truck started missing a little. wiggled all cop's and its running fine again. my milage is worse than with the old plugs.
truck has 80k.
Matt
Old Nov 24, 2007 | 04:19 PM
Ultramagdan's Avatar
Ultramagdan
Yeah you need to make sure you have them seated on plug. You should be ok now. Which plugs did you install?
Old Nov 24, 2007 | 04:25 PM
fordboy_52's Avatar
fordboy_52
autolight double plat. i was going to do all new boots until i found out how much they were. then i said f that. i had to replace one injector oring since it busted when i pulled the fuel rail off. i didnt have enough tools to do it without removing the rail
Matt
Old Nov 24, 2007 | 06:15 PM
Ultramagdan
Those are good plugs and are what I have in my 5.4. I didn't have to move the fuel rail when I did mine. The right tool at the right time is priceless and cuts down on profanity. LOL
Old Nov 24, 2007 | 06:53 PM
fordboy_52's Avatar
fordboy_52
i could deff have used a 7 mm wrench
