Sponsored by: Real Truck
Converting From A Dually To SRW
Old Nov 24, 2007 | 01:43 PM
timberon94f350's Avatar
timberon94f350
Question Converting From A Dually To SRW
Hi,
I have been looking for a 99 - 02 F-350 4x4 with a Powerstoke 7.3 & a six speed. Dually seem to bea lot more common, but I don't want a dually living on a ranch beacause the outside tires seem to alway be flat from being out in the brush on "two track" roads. Whatever I get I will put a flatbed on, so the bed will not be a problem. What would be required to turn a dually to SRW? Would I need different spindles? Any input would be helpful. Thanks very much!
Old Nov 24, 2007 | 01:59 PM
redford's Avatar
redford
FTE Leadership Emeritus
I guess you could just pull off the ouside set of tires to make an SRW truck, but watch your tire loading.
Wouldn't it be easier just to purchase an F-250 or F-350 SRW truck?
Old Nov 24, 2007 | 02:04 PM
timberon94f350
Thanx, But how about putting a set of wheels & tires off a F-250 or F-350 SRW? Will they match up?
Old Nov 24, 2007 | 04:29 PM
timberon94f350
URGENT HELP REQUESTED PLEASE!!!!!!!!!!! Getting ready to bid on one on flea-bay & I need to know as auction closes tommorrow.
Old Nov 24, 2007 | 04:33 PM
krewat's Avatar
krewat
I THINK that you can just remove the spacers on the front, change the rear hubs, and you have an SRW. Not even sure changing the rear hubs is necessary.
Although, I think you might have to change the wheel bearing (big $) if the face of it won't match the rim.
It's doable.
Let's let more people answer though before you go and shell out money, OK?
Old Nov 24, 2007 | 04:35 PM
thorseshoeing's Avatar
thorseshoeing
decadent and depraved
Damn, if you lived closer to me I would trade rear ends with you...I'm wanting to convert my 250 to a dually...
Tim
Old Nov 24, 2007 | 04:55 PM
jake00's Avatar
jake00
why not just pull off the outer tires?
Old Nov 24, 2007 | 05:20 PM
timberon94f350
I would like to put on regular wheels & tires so they match my stock trailer. I also like the looks of a SRW better but they've disappeared off the face of the earth here unless they have over 200k & the everliving you know what beat out of them. Or unless they're a dually.
Old Nov 24, 2007 | 05:22 PM
krewat's Avatar
krewat
That'd be pretty unstable, wouldn't it?
And it would look weird
Old Nov 24, 2007 | 05:24 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Are the axles longer on a dually? With the dished rims and all?
Old Nov 24, 2007 | 05:27 PM
timberon94f350
That is a good question. Would the track crooked with SRW wheels and tires on it? Aren't dually rear ends narrower than SRW?
Old Nov 24, 2007 | 05:46 PM
krewat's Avatar
krewat
Usually, the front wheels are in the center of the rear two.
The spacer on the front offsets the already-offset wheel so the effect is neutral.
The rear, the two wheels are opposites and identical so the center line is still the face of the hub.
Whether or not the overall width of the DRW is different than an SRW, I have no idea.
I don't think it really matters much unless the original poster is fussy about his fenders getting hit with crud
Old Nov 24, 2007 | 05:48 PM
timberon94f350
I know I had a 91 F-350 flatbed 4x4 SRW & we put duals on it to move a single wide. It seemed alright for a temporary job, but that was also drum & not disc brakes. Aren't the rear brakes different on a SRW than a dually?
Old Nov 24, 2007 | 06:59 PM
davidw221's Avatar
davidw221
I have a 2000 f350 in perfect shape, and lots of xtras, maybe we could trade? I need a crew cab the kids are getting big, hate to part with my baby doll, but I need the room,
Old Nov 24, 2007 | 09:02 PM
timberon94f350
Love to, but the one I'm bidding on is a super cab, & I need that space for ranch supplies that can't be left out in the weather.
