open air clearner
Old Jan 7, 2002 | 01:00 PM
muddogin400's Avatar
muddogin400
open air clearner
i was wondering what i would need to be able to put a open air clearner on m 84 inline. everyone i see fits 4V. are there any adapters i can buy????
thanx
Old Jan 22, 2002 | 07:39 AM
Flrsdgy's Avatar
Flrsdgy
Post open air clearner
I put an open air cleaner on mine, and it has helped the mpg considerably. I went up 1.5 mpg around town, and just got back from a trip where I got 16.5. My truck is an '81 flareside, with the 4spd. At a local auto parts store, I found an adapter that reduces the size of the opening at the bottom of the air cleaner to fit the 1bbl carb. There is a slight interference with this piece and the choke mechanism, but I fabricated a spacer of some large pvc pipe I had, which elevates the air cleaner enough to clear the choke housing. I also found that the 1" air filter element didn't look cool enough for me, so I sorted through the air filters at NAPA, and found one with the same diameter that was 4" tall. Another side benefit is that I can now get to all the adjustment screws on the carb without removing the air cleaner.
Old Jan 24, 2002 | 07:50 PM
captntim's Avatar
captntim
open air clearner
hi there...I know this is a basic question...but what exactly is a "open" air cleaner? The MPG gains seem worth it. Also, about how much can I expect to pay for this?
thanks,
captntim
'86 F150 4x4 300I6 NP205 SWB 4 speed
Old Jan 25, 2002 | 12:18 AM
whiteboyslo's Avatar
whiteboyslo
open air clearner
An open air cleaner is when the air cleaner leaves the air filter exposed on the sides. This is opposed to the stock cleaner which entirely encloses the filter. Of course, these are only found on carburated trucks, so if you have EFI, it really doesn't apply.
Old Jan 25, 2002 | 05:43 AM
Flrsdgy's Avatar
Flrsdgy
open air clearner
In regards to what you'd have to pay, my whole conversion was about $30-40. I ran the cost up more than I needed to by buying a much taller filter element, and installing a longer carb stud.
'81 F-150 Flareside
300/4spd
Stock for now, with upgrades coming.
Previously known as Baitboy, then Flareside guy, now Flrsdgy.
(It's a long story.)
Old Jan 25, 2002 | 01:13 PM
captntim's Avatar
captntim
open air clearner
great...thanks. I think I'll give it a try this weekend
captntim
'86 F150 300I6 4x4 SWB NP205 4speed
Old Jan 25, 2002 | 01:30 PM
wtroger's Avatar
wtroger
open air clearner
It does apply to Efi Motors Ford is notourious for putting to small an air cleaner on there trucks. K&N makes a filter for the Fuelies that will add 1-2 mpg and definitely helps performance. It replaces the box over on the fender well and is totally (filter exposed on all sides) open filter.
Old Jan 27, 2002 | 10:03 AM
cw50must's Avatar
cw50must
open air clearner
Something you might want to think about is, when I went to this set up the first time I went out 4 wheeling in the mud, it completely caked the filter. So then I would just swap on the orignal closed one anytime I went out in the mud.
Old Feb 5, 2002 | 09:09 AM
dsc's Avatar
dsc
open air clearner
Hi, I am planning to change to an open air filter also on my 1982 f150 4.9l, My question is, what should I do with the breather hose from the oil fill in the valve cover to the Air Filter? Thank Art
Old Feb 5, 2002 | 08:28 PM
thelonerangerxlt's Avatar
thelonerangerxlt
open air clearner
Art, you can either run a hose to the new air cleaner, or install a filtered breather cap there. K&N makes several different sizes of breathers for an application like that.
Old Feb 6, 2002 | 11:36 AM
77fromheaven's Avatar
77fromheaven
open air clearner
florida_1959
May 1, 2013 04:07 PM
FORDMANMATT
Dec 31, 2012 05:16 PM
edge03
Dec 5, 2009 08:44 AM
jhorton
Mar 3, 2008 09:49 PM
