Are these measurements correct. Are these the same measurements as the dealer ship would use. The harnass and lights are comming in for me this week and iam gonna put them in.
As for those clearance lights, make sure to measure your truck height with them on it you will be heading into any parking decks... I know my poor lights need fixin, 7' just wasnt enough room for clearance!
Glad to hear you are puttin em on ur truck! post pics when completed!
I used motoman's measurements and they worked great for me. I like the spacing that he used. They fit well for the roof contour other than thetwo outside lights that either need some trimming of the base or a cut-to-shape thin rubber shim on the back portion. http://www.emotoman.com/f250/lights/f250lights.htm I'm pretty sure member mind used the same measurements in his install (another great writeup)
I used his measurements also and worked out great..
