85w-140 rear end fluid, to thick?
Old 11-23-2007, 02:43 PM
5004man's Avatar
5004man
5004man is offline
I changed my rear axle fluid today, and the only fluid my parts store had was valvoline 85W-140. Is this to thick of a fluid to be running in the winter? I dont have a manual but on the back of the bottle it says it is recommended for all hypoid differentials (conventional and limited slip) where API GL-5 or MT-1 fluid is specified. My axle is a dana 60 with 3.54 gears and a factory limited slip. So is this fluid ok, and do I need to add any friction modifiers? Thanks
Old 11-23-2007, 04:07 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,788 Likes on 1,443 Posts
That fluid should be fine. I believe you are supposed to add a tube of special stuff if you have limited slip, but I never did on mine and never had any problems. It comes in a little tube like a oversized toothpaste tube.
Old 11-23-2007, 04:27 PM
5004man's Avatar
5004man
5004man is offline
ok well so far I have read that you need to add 4oz of the modifier, but I dont want to go buy it and put it in if the gear oil is wrong. Can I just use lucas, or does it have to be ford modifier?
Old 11-23-2007, 04:47 PM
Franklin2's Avatar
Franklin2
The parts store should have it I believe. A guy gave me a tube of it he didn't need, but I never did use it.
Napa sells it. Try this link.
http://www.napaonline.com/NOLViewer/...971&ShowPics=1
VaFordman26
07-02-2017 07:48 AM
1L243
22
03-26-2017 03:41 PM
twall_SD250
1999 to 2016 Super Duty
30
06-16-2016 08:49 PM
waldreps
2004 - 2008 F150
08-23-2015 10:34 AM
raptor131
09-15-2009 09:31 PM
Quick Reply: 85w-140 rear end fluid, to thick?
