bad starter?
Old Nov 23, 2007 | 01:45 PM
gnwalker's Avatar
gnwalker
bad starter?
I have a '94 150 with a 4.9 manual trans, a year old battery and new alternator. The problem started a month ago when every other time I went to start it the starter would grind a little. Then when i would try to start it the sarter would do nothing until I hit it with a hammer a few times and it would start. Now in the past few days it makes no attempt to start no matter how i hit it with the hammer. I would say its locked up and just get a new starter but also in the past few days the door chime only works sometimes as does the radio and instrument panel when the key is turned to the on position. I've checked the battery cables and their connections, solenoid wiring, etc. Any help would be appreciated before I spend a $110 on a starter
Old Nov 23, 2007 | 02:52 PM
17fordguy's Avatar
17fordguy
best thing would be the 110 dollars for the starter.
Old Nov 23, 2007 | 03:53 PM
flareside_thunder's Avatar
flareside_thunder
Do the starter...as for the door chimes...My 95 has issues with the chime too...I gotta jiggle the keys to get the damn thing to shut up!ha ha ha....Luck
JR
Old Nov 23, 2007 | 04:01 PM
dave2's Avatar
dave2
If you have the opportunity to get a Bosch starter, you may want to pass it up. I'm having problems with my second Bosch in a year........ Good luck.
Dave
Old Nov 23, 2007 | 04:35 PM
gnwalker's Avatar
gnwalker
I guess thats what I'll do. thanks
Old Nov 23, 2007 | 05:44 PM
lostin90s's Avatar
lostin90s
Dont hit the newer starters with hammer the mags r glued in. I can get rebuilt locally for like$75 bucks was 123 for starter and alt. check you local rebuild shops They will give u better idea whats wrong. . Later
