89 f-150 stumbling problem....
Old Nov 23, 2007 | 01:28 PM
mharmer34's Avatar
mharmer34
Exclamation 89 f-150 stumbling problem....
I have a 1989 f-150 with 88343 original miles!This truck has always been maintained by the dealer.The problem i am having is this.The truck runs excellent,but as i go down the road,it seems to "stumble",or miss..its real quick and then goed right away.I replaced teh o2 sensor as that code and code 67 came up on the scan tool.I am thinking the ignition control module might be going bad ?any ideas?..I know code 67 is the "neutral gear switch",but i cant seem to find any info if that might be causing my "stumble".Thanks for the help.....by the way...its a89,4.9l 6 cylindr,5 spd manual tranny...
thanks again, matt
Old Nov 23, 2007 | 02:10 PM
Ultramagdan's Avatar
Ultramagdan
Welcome Matt!
You will want to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and scroll down to the 87-96 forum to get the help you need. For local information and support be sure and stop in your state chapter: https://www.ford-trucks.com/forums/forum116/
dobber7777
New Member Introductions
Oct 23, 2007 09:28 PM
cajunjoey
Sep 23, 2007 05:56 PM
bigal66
Apr 3, 2007 09:11 PM
Richardwoods
Mar 8, 2007 05:05 PM
CRGIFT
Jan 8, 2007 07:26 PM
